Question about Sprint Hitachi P300 Cellular Phone
My Hitachi AX-M79 stereo has locked up on the welcome screen
I have turned the AX - M79 surround sound system off and all the components atached to it but when I turn it back on the 'Hello' Welcome appears on the screen and cannot be removed - the sustem cannot be turned off or on from the on/pff button and it has to then be turned off from the mains
Hitachi tv sound problems
If you are running this through a cable box then you need to run a separate pair of audio from the box output to the input of the TV. If This is from a stereo system then you need to run audio from the cable box to the stereo component and select the proper input after it is turned on.
Aug 22, 2014 | Hitachi Televison & Video
I own a hitachi av surround reciever model No. HTA-DD3W. It has recently developed a problem in that it does not play in any other mode than stereo, ie no surround sound, multi stereo etc. please help
Hi amstok
Sounds like it may have a DSP failure. Straight stereo signals bypass the DSP stages. Could be an expensive fix. I suggest you take it to a Hitachi agent for a quote. Not something that can be easily fixed on the kitchen table I am afraid.
regards
Graeme
Mar 08, 2008 | Audio Players & Recorders
Sony TA-AV521 I have had this stereo system with surround sound for years. Recently I am finding that the surround sound mode is not working right. There is a lot of fading in and out whether it is on...
CD's and FM radio are created in 2 stereo channels. To listen to them in Surround, artificial processing has to take place in your receiver, so artifacts and fading are quite common when you do this. When you turn the surround off, your stereo is processing the information properly and it will sound right.
Mar 02, 2011 | Audio Players & Recorders
Dont know how to get the stations tuned in on Hitachi Stereo
best bet is go to there internet site and then support download the manual
Mar 12, 2010 | Audio Players & Recorders
Hitachi AXM82D midi system will not turn on and stay on
Check if the biggest electrolytic capacitor on the small psu subpanel with the standby transformer is bulged - on my unit, replacing this part restored normal operation.
Jan 14, 2010 | Audio Players & Recorders
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
Hitachi AX-M71 connecting control cable
Hello Alan, I have the cable from a u/s AX-M71 system. the cost is £8.00 including P & P . Regards, Malcolm
Aug 05, 2009 | Audio Players & Recorders
Attaching a surround sound to a Hitachi 60CX29B
the red green and blue are component video
to get the surround sound to work the red and white audio outputs from the tv go to the audio inputs on the reciever , and to get the digital surround sound the optical also has to be hooked up
Nov 06, 2008 | Hitachi 60CX29B TV
Sprint Hitachi P300 Cellular Phone Logo
160 people viewed this question
Top Sprint Cell Phones Experts
TekkiDave
Marvin
Marvin
 Mikey
Mikey
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
