Question about Hotpoint TDC32 Electric Dryer
My hotpoint aquarouis ctd00 tumble dryer is heating but no air is blowing through. also there is no water collecting in the water tray
  • 1 more comment
  • emmagerrie Dec 27, 2008
    we do not overload dryer, we only put a small amount in as it was taking too long for a bigger load to dry. we have checked all filters and cleaned them all. we also checked tubes at back. why would there be no water collecting in the tray? when we first gor the dryer, the tray would fill quite quickly, now it is bone dry and clothes take all day to dry. please help, our washing is piling up and we cant afford to get anyone out to fix this. thankyou
  • emmagerrie Dec 28, 2008
    i solved the problem, the large filter on bottom left was blocked, i took this out and ran hot water through it the clear. now works like new.
    you did not tell me how to clear that filter, how was i supposed to know you had to run water through it a certain way. this was advised in the m,anual which i downloaded from the hotpoint site. so just telling me to check filters is not enough when you do not say location of filters and how to clean them. but thanks anyway.
  • Hotpoint Master
  • 3,463 Answers
Check all filters and air vents at front and rear of m/c, to make sure they are all clear., do not overload, make sure you have selected right heat setting, and the correct drying time.
It is not usual to feel air blowing out of dryer, because it is a condenser dryer.
Plz rate my solution.
Thanks.
Posted on Dec 27, 2008
  • Barry Coates
    Barry Coates Dec 27, 2008
    At the rear of the front lint filter is a small hole that can get blocked with fluff and gunge, remove the filter draw, reach in there and clear as much as you can, get a plastic bag tie or something similar and feel for the hole and poke clear.
    If this is blocked then this could be the cause of your problem
  • Barry Coates
    Barry Coates Dec 28, 2008
    Glad to hear you solved your prob, if you recall I said make sure all filters are clear, and you assured me they were, apparently this was not the case.
    Under the circumstances,I would have thought my solution warrented a FIXYA.
My hotpoint ctd00has stopped heating up how do i
You will find the thermostats located at the rear of dryer.
Remove cover, and you will see them adjacent to the heater element, change them both, even if only 1 is faulty.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Hotpoint Dryers
Why is my hotpoint ctd00 condenser dryer leaking water from underneath and turns the electricity off''
you are not on your own we have the same problem we are going to convert back to the old fashion tumble dryer
Dec 23, 2009 | Hotpoint Dryers
Dryer revolves but no heat on any settings . hotpoint aquarius tumble dryer CTD00 7Kg.
fixed using posted advice on resetting thermostat.
Many thanks
Dec 10, 2009 | Hotpoint Dryers
Hotpoint tumble dryer CTD00 timer
It is not a difficult job...the thing to keep you out of trouble is to make sure you get the right timer switch, then remove one wire at a time.
Remove one wire from the old timer and put it on the new timer, there is not that many wires for your timer.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 05, 2009 | Hotpoint Dryers
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hotpoint CTD00 condenser dryer not heating up
sounds like a thermostat fault, there is two on these machines and although only one will be at fault both should be replaced
Jul 24, 2008 | Dryers
How to fix Hotpoint CTD00 Tumble Dryer?
http://www.fixya.com/support/t232066-hotpoint_ctd00_trips_power
The link above should solve your problem. I have the same problem and my parents who bought the same tumble dryer also had the same problem. Its water backing up to the fan then its hitting the heating element which is tripping the electric off.
At the back of the Tumble dryer near the bottom you'll see a panel that has about 8 screws that you can taqke off as well as a small panel that cover the pivet for the drum. If you unscrew this you will see the fan and heating element and no doubt a small puddle of water and damp dust that has clung onto the panel. You should dry this with kitchen roll and clean the old dust off then carefully turn the tumble dryer on (at your own risk lol) or you can take the advice of the person who posted the link above and use a hair dryer. This will stop the element getting wet and tripping off.
Also there is a water reservoir to the right of the panel i mentioned. If you prise the clips open and remove the top section you will see the water in the reservoir. If you look inside it on the bottom left hand side there is a little **** that the water drains in from. If you use something like pipe cleaners or a knife and wiggle it about you may have some fluff or hair trapped there that is making the water back up to the fan and causing the tumble dryer to trip off.
Hopefully this willsolve your problem for the time being but the filter in the bottom of the dryer needs to be cleaned thoroughly every week or so to stop this happening again.
Personally i think this is a major design flaw and the tumble dryer should be recalled but Hotpoints aftercare service is awful to say the least so lesson learnt, don't buy a hotpoint tumble dryer!
Feb 01, 2008 | Dryers
Hotpoint TDC32 Electric Dryer Logo
345 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
