Question about Refrigerators
Cold Freezer and warm fridge
I've checked the usual, cleand the coils, motor is running, canfind any fans, cleared internal air vents in fridge, even held a lighted match to check air flow but nothing, nnow evening here in NZ and its cooler outside the fridege than inside. I have even switched it off for 10 mins, but no change. Is this a throw away, or is ther still hope???
  • Theworkmans Dec 29, 2008
    We have the same issue and did the same checks with no result- any ideas?
  • robertrt Dec 30, 2008
    Warm fridge cold freezer problem fixed
    In the freezer section there was a one screw removable panel which housed a four bladed rotary fan. One blade had broken off adn was jamming the fan from rotating. Once the broken part was removed the fan was free to rotate, but out of balance, but it did get the fridge going again. It took about one minute to replace the fan once a spare was aquired. Now I understand how it works, if one side of your fridge freezer is not working it can only be the air movement or lack of it Robert
    Robert
    Top Expert:
  • Refrigerators Master
  • 53,736 Answers
Possible thermostat problem in the fridge section
call a technician for a proper diagnosis and quote
make sure that the door seal is in top condition and the door closes properly
Posted on Oct 17, 2017
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: FREEZER COLD REFER WARM
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 12, 2010
  • 279 Answers
SOURCE: I have an F&P E522B frideg Freezer, freezer works but fridge warm
Firstly you must totally defrost the unit, turn it off empty it & leave the doors open for at least a day or overnight, if the fans are working then ice is blocking the return air duct.
Posted on Nov 30, 2011
GR-349SQF won't freeze
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
R
Jan 17, 2012 | Refrigerators
Freezer is too warm. We have cleaned all vents but is still in the 40s
Regards.
Sep 15, 2011 | Maytag Freezers
My danby 3.6 chest frezzer has stoped working, it was freezing fine yesterday, now its not even keeping cold
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Good luck.
Apr 14, 2011 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer too warm
Let's start by diagnosing the freezer;
Good luck.
Apr 07, 2011 | Fisher and Paykel Refrigerators
Freezer not getting cold
Good luck.
Mar 29, 2011 | Refrigerators
Reefer is working fan in freezer is working freezer is not freezing
Good luck.
Mar 22, 2011 | Refrigerators
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Warm fridge
Hi and welcome to FixYa,
Initially, this normally would point to the fan not spinning. The function of the fan is to draw the cold air from the freezer and force it through the vents to the refrigerator area. Even having said this, the fan is activated by the logic controller based on the the thermostat setting of the refrigerator and condition of the door (it must be closed).
To check:
  • fan - open the door, locate the door switch, press on it, light should go off, fan should kick in within 60 seconds. If not, faulty fan, fan relay, or controller. Alternately, you can measure the continuity of the motor's coil and or if there is voltage going to the terminals of the motor;
  • thermostat refrigerator side, you would need to use a continuity tester or have an electronics shop perform this. At room temperature the reading should be low, and should go high when the probe end is submerged in a glass of cold water.
Alternately, it may be the vents, flaps or vanes that are stuck, clogged, blocked and hence no air flow from the freezer to the fridge side.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 12, 2008 | Refrigerators
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Mar 04, 2008 | Kenmore 64823 Top Freezer Refrigerator
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
