Question about Compaq Presario Notebook
Dear Sir I'm unable to install the Windows Xp in my new laptop i think this problem is with sata HDD so can i download the drivers and install in my laptop
  • DJ000
    DJ000 May 11, 2010
    could you tell me what error message you are getting ?
    Problem Solver:
  • 15 Answers
XP does not have the drivers needed for the SATA drives for the newer HP laptops. Either you need to "slipstream" the installation to contain the drivers using something like Nlite (free software) or you need to go into the BIOS and set it to HD compatibility mode. If you set it to compatibility mode, you should be able to install XP without any additional drivers
Posted on Dec 27, 2008
    Genius:
  • 1,913 Answers
Check in bios settings the sata hard disk detect or not.if not detect then u cant install. Reset your bios settings to defaults settings then save and exit.
also check your sata option in bios is enable.try in both situation sata enable and then try sata disable.
  • kishor khatri
    kishor khatri Dec 27, 2008
    check in bios settings the sata hard disk detect or not.if not detect then u cant install. Reset your bios settings to defaults settings then save and exit.
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
I want to instal a windows XP SP3 on Foxconn 915 series with north bridgegrantsdale G-i915G with a IDE H.D.D (pata) and sata O.D.D,it seems that i need a floppy disk for raid driver,but i lost motherboard...
There are a couple options.
  • Check in BIOS to see if your motherboard supports IDE emulation mode. If it does turn it on and XP will install just fine.
  • Download and read about using nlite to incorporate sata drivers into an Windows XP installation disc. (You will need another working computer. Download nlite and insert the XP disc run nlite and select your CD as your windows install file location. Download generic sata drivers, intel has a bunch you can get for free. In the nlite menu to add drivers select folder option and select the folder with the drivers. Set anything else you want in nlite and burn the new XP disc. This disc will install just fine as it now has sata drivers.
Comment if you need further instruction.
Aug 18, 2011 | Foxconn 915P7AC-8KS Motherboard
How to get software for downgrade from vista basic to xp sp2 oper
first you download a sata controller of your hdd because winxp sp2 will not support a sata controller after you finesh download the sata controller copy the installer of windows sp2 then compile it again to gother sata contraller. or just download a windows sp3 has updated inculded sata controller that is the easy process
Mar 04, 2010 | HP Pavilion dv6000z Notebook
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | Compaq Presario Notebook
Not Changeing sata to ata
You will need to go into the BIOS and disable SATA RAID. then windows XP setup will show the HDD.
Jul 02, 2009 | Microsoft Windows XP Professional With...
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to...
If your laptop is still under warranty, installing WinXP will void the warranty. It's very tricky. I'd suggest getting another PC with Internet connection and search and download drivers as needed for your 1525. Good luck.
Jun 13, 2009 | Dell Inspiron 1525 Laptop
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
XP on HP Pavilion dv2000
Your laptop probably has a SATA HDD. you'll need to download the SATA drivers for you to be able to install windows XP. Click on the link below to download the drivers that you need.
SATA Driver Download Link
Sep 18, 2008 | HP Pavilion dv2000t Notebook
Help me to install WinXP in a Gateway Laptop that came with SATA HDD
you have probably already fixed this but maybe others can find this a little helpful. i had to downgrade a gateway ma7 for one of my customers who had lost their recovery cd with vista on it. Their HD had gone bad.
The reason the XP installer says "no HD" is because the the drivers required by the gateways Sata controller (hd controller) are not preloaded on the xp install disc. The only way around this is to download the windows xp compatible sata drivers from gateways website and then slipstream them into a custon windows xp install cd. its actually not as difficult as it sounds. just download the sata driver, a slipstreaming program called nlite.
1 download and install nlite
2 put in your xp install cd, and run nlite, when nlite asks, browse to the i386 folder (your installation files)
3 you will have lots of options to choose from, but for this purpose, choose "add drivers" and select the location of the gateway drivers (c:\cabs\something) i think.
4 finish and burn the cd. then use it to install windows xp.
this little guide isnt step by step, but with a little trial and error you should get by
-Nele, MCSE
Jul 19, 2008 | Computers & Internet
How to install XP in toshiba Satellite L45-S7423 laptop
I found it!!!>>>
Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
Mar 27, 2008 | Computers & Internet
Compaq Presario Notebook Logo
140 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
