Question about Mitsubishi VS-45605 50" Rear Projection Television
PIP function The PIP circuit board on Mitsubishi projection Tv's go bad and may render the picture to go out completely. I know a PIP circuit card is available that will bypass the PIP function and fix the problem. My Tv is still fuctioning, however the PIP channel scrolls. Should I replace the board before it goes completely bad or leave it alone? Rexman
  • Anonymous Mar 12, 2014
    I HAVE A 65INCH PROJECTOR TV
    Scholar:
  • 77 Answers
The Main Picture will eventually go out or at least become distorted. Generally the PIP circuit can be repaired by replacing a couple of capacitors. Probably a job for a Pro but it will need to be done at some point.
Posted on Apr 21, 2007
SOURCE:
Mitsubishi tv model VS6061 rear projection with rolling picture.
I know this is an old thread, but I would like to post this information in the hope that someone will find it useful.
I just finished fixing this problem on my 1994 VS-6061... the problem is the PIP (Picture In Picture) board located on the Power Signal board. The PIP board contains the numbers 530B552. I bypassed the PIP board by following the directions I found at the following link:
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/130383-mitsubishi-cs-35301-rolling-picture-problem.html
"Plug in a 4.7ufd @ 35v filter cap (+)at pin 5,(-)at pin 11. Plug in a .01ufd(any voltage) between pin 7 and 9. Just plug the caps into the socket, where the PIP board was mounted (they don't need to be soldered). Just don't let the leads from the two capacitors touch, as they cross each other. The 0.01 cap is non-polarity, so either way it plugged is fine. Basically you will bypass y-signal through 4.7u, in pin 5, out pin 11, and bypass c-signal in pin 7, out pin 9 of the PIP socket.”
The bypass requires 2 capacitors: One 4.7ufd @ 35v and one Non-Polar 0.01ufd @ any voltage.
Remove the PIP board, then plug the two capacitors into the socket where the PIP board was mounted: plug the 4.7ufd capacitor with (+)at pin 5,(-)at pin 11 and plug in the non-polar .01ufd capacitor between pins 7 and pin 9.
If there is a ground wire (possibly brown) soldered to one of the tin cases on the PIP board, then you should connect this ground wire to the PIP socket either at pin 2, 4, 6, 8 or 10 which are grounds of the socket.
This PIP board was used in many Mitsubishi televisions and they were plagued with problems...This is why many of these older Mitsubishi televisions had similar problems…
Good luck
Jul 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
PIP fuzzes out, then snaps back in
It is definitely a circuit problem tf
it could be the pip board and or
components on or around it.would
require technical knowledge to
repair
Nov 30, 2007 | Sony KP-57HW40 57" Rear Projection...
Whats a quick solution
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
My mitsubishi vs 5071
You might have a bad PIP board, When you say NO picture. Is it totally blacked out or blacked out with "blue snow". The PIP has been alot of problems in this chassis and you will experience what your describing. Capacitors are the root of the PIP boards failure. Let me know if I can assist you further.
Jan 26, 2008 | Televison & Video
My tv
This set is known for some very common problems some of which is just what you described. For a small fee, I can give you some common solutions that will take care of these and other issues. The only problem is you must know how to take things apart and put them back together without doing further damage, AND you must know how to solder /desolder components.
Dec 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Oct 27, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Scrambled Picture (Vertical Sync) Mitsubish VS6883
Im looking for an owners manual for a Model VS683R Mitisubichi
TV anyone know where I can get one copied or buy one??? thanks Grant please e-mail me at WGA@aol.com
Oct 21, 2007 | Televison & Video
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
Oct 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Pip only on screen
Try hard reset first==Unplug ac cord overnight, then try again.Possible signal board trouble-- Practice visual acuity technique==look for CRT coolant leak on circuit board. Also suspect PIP PCB==can be by-passed by a knowledgible tech.
Sep 26, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Sound no picture
You can buy a PIP circuit card on the internet(about $15.00) that can replace your current PIP card. It will bypass the PIP function which is most likely the problem. Instructions for instal come with new card. It's a relatvely easy task if you are in anyway technically capable. Worth the try. Rexman
Apr 05, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
231 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
