Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Coffee bean container light on
Dregs drawer light on my Saeco Incanto Classic is flashing even though the dregs drawer is empty; at other times the coffee bean container light is 'steadily lit' although there are coffee beans in the container. In this instance the beans are ground and then discharged (unused) into the dregs container. It's such a waste of coffee beans and it drives me mad.
SOURCE: Saeco Incanto Flashing Red Bean Light
I found a machine in my dentist's office with this exact same problem. I'm not familiar with the model, so I downloaded a manual for the closest model I could find online (the Sirius), and it offered no help -- but in 8 languages!
I ended up just pulling the drip tray, pulling the box where the grounds end up, and re-inserting the assembly (all while the machine was on.) When I buttoned it up again, it worked.
Hope this helps (although I can see how it might not...)
Posted on Nov 15, 2007
mirran
  • 515 Answers
SOURCE: Saeco Incanto Classic - Bean feed problem
First, make sure you not get any damp into your grinder.
If you get damp into the grinder then it will not grind the beans.
To check the grinder you have to loosen the three screws in the beanhopper and lift it up.
The jagged plastic in the machine you will see when the beanhopper is off, turn it anticlockwise to you can see
the claque is free, then you can take out the jagged plastic and you will see the grinding wheel, make sure the wheel and the jagged plastic is clean.
Before you mount all again, use a vacuum cleaner to clean it.
Put back the jagged plastic again and turn it clockwise to it stop, then you turn it anti clockwise 14"click".
Set the number to 8 on the beanhopper and mount it again.
Hope this will help you.
Best regards
/Mirran
Posted on Aug 30, 2008
  • 24 Answers
SOURCE: Removing Saeco coffeemaker dregs container
The dregs container comes out with the drip tray. Lift up on the drip tray and slide it out. If this doesn't work then the brew group is out of position. Turn the machine off then on so that the machine goes through a self test. This will reposition the group allowing removal of the dregs container.
Posted on Apr 24, 2009
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have had the same problem the only way I could get it to brew would to use the program quantity feature every time. I was going to take it in today and decided to restore the factory settings and now its working like it should. This seems to be a circuit board issue Ouch! I have another issue with the steam, if I take the knob off it works if I don't it doesn't glad I bought a 2K model GRRRRR!
Posted on Jan 25, 2010
  • 1089 Answers
SOURCE: My Saeco Incanto Deluxe occasionally
Hi
Grounds and water under the machine or drip tray indicate that the drain behind the brew unit is plugged.
Remove the brew unit. You will see the injector in the back of the machine. Below the injector is a pocket that the excess pressure is relieved into when the machine is done making a coffee. This pocket will plug up with ground and oils. The drain is just above the center of the drip tray. Insert something into the drain and see if you can unplug it. Once it has drained run some hot soapy water through the pocket.
Posted on Apr 17, 2011
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
I have a Saeo Incanto Tondo S Class coffee maker. It grinds coffe bean but coffe is not coming out. There is no water in dregs but only grined coffe powder. I can get steam and hot water and I do not find...
Hello Saaddition,
I understand that your coffee maker is not producing coffee. However, it is operating normal in all other respects. This is usually a common problem when the machine needs to be descaled. You may also need to clean the brew unit. Here is the link to the manual for you Saeco Incanto Rondo C class coffee machine it give you all of the directions to clean and descale.
One other question did you remove the dregs drawer with the machine off. If you did you will need to do cleaning to reset the machine as removing the dregs drawer with the machine off will not allow it to brew coffee.
Thank you for choosing FixYa.com
Justin
May 08, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Flashing beans/dregs light -- can't start machine.
Hi
Either you dredge drawer is missing.
The tab in the back of the dredge drawer is broken.
The microswitch is bad for the dredge drawer.
The grinder motor is bad.
Apr 23, 2011 | Saeco Incanto Classic Espresso Machine
The light won't come on when the dregs drawer is full. this machine is about 3 months old.
Hi
The machine is a counter. When 16 cycles have been met the light will come on to tell you to empty the box. If you empty it anyother time it will be out of sync, and you will not get the light when it is over full. Empty it when the light comes on and the only when the light comes on and you should have no problems.
May 07, 2010 | Saeco Incanto Classic Espresso Machine
My saeco incanto doesnt dispense coffee any more only water comes out of the dispenser :( please helppppp ,it was working fine an hour ago then suddenly i start getting only water instead off coffee , P.S...
Check the coffee dregs are they wet? Or are they even there?
If there are no dregs then the grinder chamber is clogged and needs to be cleared out, remove the brew unit and you can gain access to the chamber on the left. Clean the chamber.
Jun 25, 2009 | Saeco Incanto Classic Espresso Machine
Apr 24, 2009 | Saeco Incanto Sirius Fully Automatic...
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
I have the saeco incanto sbs rapid stream and the red light stating that the door is open will not turn off
that can mean that the brew group is not in the right place, the dreg drawer or door.
Please check all three of them
Apr 07, 2008 | Saeco Incanto Classic Espresso Machine
Dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
Apr 06, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Apr 05, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
247 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
