"-36" error message using Acomdata External Hard Drive
Have a new Acomdata 500 GB External HD. Using it with an eMac 1.42 GHz PowerPC G4 with 512 MB DDR SDRAM. Seem to have installed it properly, then began trying to move movie files. Several files moved properly, but since then all I get is a "-36" error message. My Mac is in desperate need of moving these files to the EXTERNAL, to free up memory. These movie files are chewing up space. But what's with the Acomdata? And the error message? And how to fix???
    Novelist:
  • 146 Answers
Have you tried taking the files off of the drive and repartitioning and reformatting the drive?
How is the drive formatted? Fat? Fat32 or HPFS? What version of Mac OS are you running? It is possible, depending on the version of the OS and the driver for the OS that it can have problems with drives that have partitions larger than 128 GB. It is also a bios limitation with older systems.
Look to see if there is an updated driver for the OS X version you are running.
Also check in the Disk Utility to see how the drive is partitioned and formatted. If it is going to be a Mac only drive, partition and format it as HPFS. If it is a drive that you will use in Windows as well, use Fat 32 and limit the partitions to 128 GB or less.
You could also try a newer version of OS X like Tiger or Leopard. They are both more stable than older versions and have better support for devices.
Cheers and good luck.
Best
Posted on Dec 27, 2008
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Install Snow Leopard on a macmini Power-PC ?
If it is a G4 PowerPC processor No
If it is an Intel Processor Yes
Jan 06, 2010 | Apple Power Mac G5 Desktop
LG External Super Multi DVD Rewriter has frozen
there's a mini hole in front just put the needle or something like that and
push presto it will open try it!!!!!!!!!!!!!!!
Apr 27, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
How to eject (exit) from nomad mobile desktop program/acomdata e5
Have you tried changing your display size for you computers desktop?
Try a higher resolution first, then if that doesn't work try a lower resolution.
Most like the items are there and your display resolution is the problem.
Jan 03, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Sep 12, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Computers & Internet Logo
95 people viewed this question
Alun Cox
David Payne
David Payne
