Question about Tally T2265 Dot Matrix Printer 917402
2265+ ribbon error
JUST FITTED NEW RIBBON, PRINTER WORKS A VERY SHORT TIME THEN GIVES MESSAGE RIBBON PROBLEM AND RESTARTS FOR A SHORT TIME AGAIN IF I PRESS ON LINE BUTTON. I DO NOT KNOW IF I AM FITTING THE RIBBON CORRECTLY AS I DO NOT HAVE AN INSTRUCTION BOOK.. I WOULD LIKE ADVICE OR AN INSTRUCTION BOOK
The Ribbon can only be installed correctly as you have to lower a bar after to allow the printer to start if it was in incorrectly this arm would not lower and you would get no printing.
Instruction manual will explain better
http://www.softwaredriverdownload.com/download.php?file=964rxfbkkrZnRwOi8vZnRwLnRhbGx5Z2VuaWNvbS5jb20vcHViL2dlbmljb20vZG9jcy90YWxseS9zZXJpYWwvdDIyODAvMDYzMDUwYV9vbTIyNjVfZ2IucGRm
Posted on Apr 29, 2009
Bc sensor error
Bar code read error: The printer does not detect the presence of the ribbon bar code sensor
1. Power down the printer. Remove the ribbon and wipe the two lenses of the ribbon bar code sensor with a lint-free cloth or cotton swab.
2. Install the ribbon and power on the printer. If the message appears again, replace the ribbon.
3. Power on the printer. If the message appears again, power down the printer and remove the paper path or top cover to gain access to the card cage. Make sure the cable from the ribbon bar code sensor to connector J122 on the controller board is undamaged and has a good connection to J122.
4. Power on the printer. If the message appears again, power down the printer and replace the ribbon bar code sensor.
5. Power on the printer. If the message appears again, power down the printer and replace the controller board. Record the message and return it with the defective board.
I have the parts in stock if needed cardenas_rory@hotmail.com
May 06, 2014 | Printronix P7005 Matrix Printer
Datacard CP40 Plus printer with an error. Put a new ribbon in it and it does give us a error message: Error: PR-01739 Ribbon Error Please Help!
Sounds like you are using an incompatible ribbon. Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Contact TulsaBiz.net for more info
Jul 22, 2011 | Datacard SP55 Plus Printer
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
Hello, my zebra ZM 400 keeps giving me the message of paper out/ribbon out I have replaced both rolls, powered down. Printer feeds one time, then keeps giving the same message
please kindly check the ribbon and label... make it sure that it fits exactly or properly or correctly fits the said consumables... if its not work check the settings...
Nov 17, 2009 | Zebra Z4Mplus Label Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
RIBBON ERRORS
Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
- The ribbon roll is not correctly fitted to the spindle.
- The sensors detecting the rotation are out of order or completetly filled with dust or grease.
In this case clean the sensors.
Another reason may be due to Direct thermal printing with a ribbon mounted.
Mar 02, 2009 | Toshiba TEC BSX5 Thermal Label Printer
"check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
I keep getting message insert ribbon parameter card and below it resolve error to resume printing
The "ribbon parameter card" is a little chip that is delivered with every newly bought pack of ribbons. You need to insert this card in the fitting slot of the printer (at the backside I assume), and let the printer read the contents of the chip. Once finished, you can remove the card.
You need to follow this procedure for the printer to be able to work with the new ribbon. If you do not have the chip for that ribbon you can not use it.
Oct 12, 2008 | Office Equipment & Supplies
Service error 5100 on canon pixma mp130
When this happened to me, I beat my head against the wall until I finally figured out that the waste ink absorber on the right side (spongy looking thing), was overflowing, and clogging the nozzles. I took a piece of paper towel and absorbed some of the ink. Make sure to wipe the colored ink absorber as well.
Neal Moilanen
AAA Virtual Assistants
http://www.aaava.net
Jan 24, 2008 | Canon PIXMA MP130 All-In-One InkJet...
278 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
mohamed salim shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
