Question about Dell 962 Photo All-In-One InkJet Printer
"Dark Smudge" upper left corner from scan
Help! The scan function leaves a triangular darkened smudge on documents. This always occurs on docs auto-fed and, after one warm-up copy, appears on all manual scans too!
Of course, dirty glass is easy to test simply by using the copy function too! I'm afraid that it is the fuser, that realistically means replacement of the entire printer (or using it only to copy and print from from the computer)! Any help on the parallel magenta lines. I have replaced the toner cartridge (and obviously set the printer settings proper from Windows software)! DOES ANYONE KNOW HOW TO RESET THE FIRMWARE IN THE PRINTER!!!!
Posted on Sep 09, 2007
    Genius:
  • 2,985 Answers
Clean the glass. If there colud be failing CCD- to prove this do a scan to PC and check out the saved image If it is still there- check out Dell for replacement machine
Posted on Sep 08, 2007
Scanning duplex I get a line down the righthand side of all alternate pages?
With very limited information, I suspect if you observe closely on the side that has the line printing you will find a dark smudge on the glass. If this is found you should be able to use a little rubbing alcohol on a clean cloth an remove the smudge.
Mar 28, 2016 | Fujitsu ScanSnap iX500 - document scanner
Printing is fine, copying is a black smudge
if you print correctly, the damage was photocopied unit, should be dirty, it should be cleaned.
Nov 13, 2013 | HP LaserJet 1100 Printer
My officejet pro 8500A prints black vertical lines down the page when I make a copy. I have cleaned and aligned the printheads. What else can I do?
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area.
When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
Oct 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
When scanning a red line appears on my scnned copy and runs throught the document
lift the top as if I were going to scan or copy something. I checked the glass. On the far left is a separate glass area. This is what the feeder uses to actually copy or scan a document. This had a smudge on it. I cleaned the glass and it was fixed.
Jul 27, 2011 | Brother MFC 490cw Color Inkjet...
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Black smudge mark down 2 inches of right side of copy?
Do you see the same smudge mark if you lay the original on the platen rather than using the document feeder? If it only shows when using the document feeder, clean the scanning glass for the document feeder. It's the small glass to the left of the main glass with the cover open. Use a damp cloth and clean off any dirt or white-out.
Nov 04, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Dell All in One Printer 962-dark vertical line on photo copies
If you are running your copies through the document feeder then see if the line goes away if you make a copy directly from the glass. If the line goes away then open up the doc feeder assy. by hinging it to the left. Underneath you will find that there is a thin strip of glass that the document passes over when it is scanned. Clean this strip of glass and this should correct your problem. If there is a smudge of dirt or small line, it will come out as a solid verticle line when scanned.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Brown smudges on clothes
Take a look and see if the drum near the door moves up vertically. It shouldn't move more than 3/16ths of an inch. If it does, replace the upper felt seal/plastic slide. The upper seal that supports the front of the drum on the front of the dryer is worn out to the point that clothes can get stuck in the gap between the drum and the front of the machine. This leaves brown wedge marks on clothes. While it's apart, replace the lower felt seal as well.
Apr 20, 2007 | Frigidaire FullFGX831C Size Stack Gas...
Dell 962 Photo All-In-One InkJet Printer Logo
85 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
