Question about PfaFF Hobby 4260
The footpedal in my 1209 PFAFF gets hot when I sew.
The footpedal gets hot when I sew for a while shou;d I worry? can I do anything about this?
  • 323 Answers
If your machine is turning easily the following applies.
This is a carbon pile foot control (Not Electronic) and when in use for an extended period of time(like doing embroidery,piecing quilts) the foot controller will get hot. There's nothing you can do about this except wear shoes.
If your machine is not turning freely, then if needs to be seen by a technician to find out why.
sewman7
Posted on Dec 29, 2008
My Pfaff hobbylock 786 stopped working, it is pulling very very slow, nothing is stuck, could it be the footpedal
Most likely is old dry oil that is sticking things together. Avoid trying to run the machine until it gets addressed as continued use may damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Feb 01, 2018 | PfaFF Sewing Machines
We recently received a PFAFF Synchrotronic 1220, but it came without the foot pedal. I would like to find where I can get one, and could I get the part number> Thank you
I can find almost anything Pfaff makes EXCEPT that model number. You may want to call Pfaff customer support. Go to the following link and the phone numbers are given.
Machine Support
Dec 07, 2017 | PfaFF Sewing Machines
Tiptronic 1209 stitch looping intermittantly
A stitch irregularity is often caused by a tiny burr on the needle. Try this: Unthread the machine, put in a fresh needle, and rethread.
Jul 19, 2014 | PfaFF Sewing Machines
My Pfaff 1469 sews intermittantly. Footpedal connection seem plugged in properly.
if you've had the machine serviced several times and it come back
with the same problem then the machine wasn't fixed.
if you can explain more about the sews intermittantly,, I'll try to help
you with the problem.
Dec 07, 2012 | Sewing Machines
Pfaff 1222 foot pedal
This indicates some sort of drive issue; your machine may have a belt that is worn or a bit stretched inside it connecting the flywheel to the engine.
But as a first check, does your machine have a bobbin winding clutch that you disenage by turning an inner knob on the flywheel? If yes, then just check that the clutch is fully engaged as this could also cause the drive loss.
Failing that, if your machine has not had a professionaly service in the past 2 years then probably worth taking it for one now and the mechanic can check out the drive components and adjust/replace.
Jan 04, 2012 | PfaFF Sewing Machines
Foot pedal doesn't work after replacing batteries
The circuit board has a very small fuse that could have blown. Your dealer will need to look at it. The older Pfaff computerized models like the 1471, 1473 and 1475 had a small fuse on the circuit board that could be replaced for considerably less than replacing the entire circuit board but I'm not sure if this is the case with the 7550.
Jul 24, 2009 | PfaFF Creative 7570
Foot pedal does not function on pfaff 7550
my pfaff sewing machine footpedal sticks
May 24, 2009 | PfaFF Creative 7570
Pfaff 1475 Needs to ''warm up?''
http://www.pfaff.com/
These folks are a great help, and being the folks whom built the machine will be the most qualified to access your issue.
Mar 30, 2009 | PfaFF Creative 7570
My pfaff synchromatic 1209 machine--the stop motion know keeps falling off. I have reassembled it but it will not wind a bobbin and only sews for a little while. Does it have a spring in there? I was...
You machine has a screw that fits the end of the shaft and the head pof the screw has broken. You can buy a new screw from a sewing machine dealer but if the whole assembly has come off you may need to take it to a dealer to have it reassembled properly. There is a spring inside which is very difficult to install.
sewman7
Aug 19, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
171 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
