Question about SanDisk Sansa e250 MP3 Player
The screen turned a sort of white color you can kind of see whats going on but its really pale-ish. I checked the settings and it's not the contrast.
Connect it to the PC and reformat the device... This will put it back to the original state so you will then have to reload your media
Posted on Apr 23, 2007
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
Dec 21, 2013 | Toymax Viore 42 in. Plasma TV
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
Feb 07, 2008 | Hitachi 57F500 57" Rear Projection...
Black background web pages
Step 1:
Web Pages That Do Not Display All Colors
Web pages that do not display all the appropriate colors have either a browser-related issue, monitor display problem, Windows comparability glitch or incorrect web pages Internet and HTML settings. More than likely, a setting dealing with your contrast ratio in Windows is the culprit. Once this issue is resolved, your web pages will display properly and accurately like they were designed to from the start.
Click on "Start" and navigate to the right pane and click on the "Control Panel." Click on "Ease of Access." Click on "Ease of Access Center." Click on "Set Up High Contrast" (one white and black box overlapping each other.) Check or uncheck "Turn on or off High Contrast when left ALT + left SHIFT + PRINT SCREEN." Click on "Apply" and close the Ease of Access Center. Press "ALT + left SHIFT + PRINT SCREEN" to turn on high contrast. Open your browser and go to a website to determine if color is restored to normal.
http://en.kioskea.net/faq/60-white-background-s-problem-in-web-pages
Feb 05, 2013 | Microsoft Internet Explorer 7
Severe color banding and color shifting for skin / hair tones
Think u got some kind of magnetic field interference.Move ur tv set to the right or left couple inches,just make sure not be to close to ur other electronics devices.Go in ur tv menu.Go to PICTURE.Go down to reset,the setting will go back factory setting,so the colors.See if that help.
May 08, 2010 | Sony KDL-46W5100 TV
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Hitachi 61SBX59B 61 inch has brightness and color problems
I would say the crt's are at the end of their life.
Sep 09, 2009 | Televison & Video
Mio 168 screen problem?
Have you tried contacting microsoft about this at all?
I am really not all that familiar with this device so I recommend using the "Ask Me" function for a different expert as you did for me.
I can give you a couple of suggestions. I believe there is a reset pin on the device, find it and press it. Second, try removing the battery and leave it out overnight to reset it. If either works, let me know, otherwise I don't know that much about this problem and either Microsoft or another expert would be able to help you better.
I'm sorry I can't be more help.
Have a good day.
Oct 09, 2008 | Mitac Mio 168 Pocket PC
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Sony Rear Projection TV - Red tube too strong
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
May 16, 2008 | Sony KP-57WS500 57" Rear Projection...
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
