Question about Hotpoint First Edition FEW12 Front Load Washer
Door locked on Hotpoint BWD129 Washing Machine
Door locked on machine. Has finished cycle so no draining problem. Have turned the machine off but not at the mains. Door handle moves when I tried to open the door, light flashes saying door locked.
Any help would be appreciated. Read somewhere else to disconnect from the mains to see if this resets the board?
Regards
Ronnie
  • lilfulls Dec 29, 2008
    have the same problem and now the handle has broken off. (a flashing light actually means it should have UN-locked itself)
  • 90 Answers
SOURCE: Hotpoint bwd129
I'm not familiar with this machine with out a picture, but does it have a control knob that would allow you to advance through the cycles? If so you should be able to go to a spin cycle and empty the unit. How long did you leave it unplugged? Sometimes it requires several minutes to loose its memory. If not you may need to empty the water manually as it may be a fail safe to keep you from getting the floor all wet. Take a bucket and lift the drain hose out of the house drain pipe and lower it into the bucket to empty. It may take several trips. This will not work unless the hose comes out of the bottom of the machine which I think yours does. Once empty try plugging the unit back in and see if that helps. If not the main control processor may have taken a voltage spike and has suffered irreversable damage and will need to be replaced. Please give me more info..
Posted on Feb 03, 2008
Had this same problem on BWD129, had a tech in and there is generally only one cause. Something stuck in the impeller (pump) in our case it was a shirt collar insert but is normally coins. If the machine makes any noise on the spin, this is likely the cause too (but it hasn't jammed.. yet)
Look at the front of the machine. In the bottom right corner there is a black cover.
Tilt the machine backwards so any water would run to the back of the machine.
Put a bowl under the filter cover and use a pair of pliars (other sites had said they use a special tool so I hadn't done it) to remove the cover slowly.
Remove cover & filter, check inside and remove the blockage.
This is a no fault found tech call and will set you back £106 + VAT.
Posted on Sep 22, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint wd420 washer dryer door won't open.
Press the start cancel button for at least 2 seconds, switch off, leave for 2 mins,switch on again holding the botton for 2 secs, then press start cancel buuton again for at least 2 seconds, hope fully ,this should do ths trick.
Thanks
Plz rate my solution
Posted on Jan 23, 2009
SOURCE: There is a series of
hi there,
i had similar problem . there is a blockage in the fllter , probably a small sock. the filter is at bottom right hand at front of machine .
turn anticlockwise to open.
regards
big eck
Posted on Jan 31, 2009
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
Door stay locked after finished washing hotpoint w/machine ref 9526
See if you notice any water still inside the washing machine, if so run another spin cycle to try and remove it as it will not open if there is still water inside.
If you don't see any water inside, try unplugging it and letting it cool off, the lock should release after this
Jul 03, 2016 | Hotpoint Washing Machines
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Bwd129 not draining
if your dishwasher is stopping on the drain cycle and not draining it could be a problem with the timer not kicking in to drain mode. or if it completes the entire cycle and not draining it is your pump thats bad. hope this helps.
Feb 22, 2013 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Hotpoint BWD129 stuck in rinse phase
Problem was caused by a faulty water temperature sensor. The clue was that the owner reported increasingly hot washes, then the machine stuck at rinse. A test resistor replacing the sensor allowed the cycle to finish. A replacement sensor is on order.
Jan 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
There is a series of lights flashing on my Hotpoint BWD129 washer/drier. The lights flashing are the 'door locked' light as well as the 'super wash' and '1200/600' lights. This coincides with the machine...
hi there,
regards
big eck
Aug 04, 2008 | Hotpoint Washing Machines
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint bwd129
Feb 03, 2008 | Washing Machines
Hotpoint WMA76 Leaking door and soap tray
you may be using too much detergent, or you have a blockage in the outlet.try putting it on to spin to drain out the water, if it does not drain then check the filter or sump hose for a blockage
Jan 23, 2008 | Hotpoint WMA76 Front Load Washer
Hotpoint First Edition FEW12 Front Load Washer Logo
157 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
