Question about Microsoft Xbox 360 Console
Inserted disc press play grinding sound and disc left scrapped
new xbox 360 60gb, new game inserted into drive and press play. after about five minutes bad grinding noise and disc removed leaving it badly scrapped and unuseable. am now concerned about using another disc in the equipment. did try a music cd that played ok.
  • gem_ov_pre Dec 27, 2008
    playing games in new xbox 360 arcade and console scrathed game .iam really annoyed as the game was alot of money and my sons besides hiself as he cannot play on the console.
  • btroxell06 Dec 27, 2008
    We have the same issue. Every CD that my sons use in the xbox360 gets a circular scratch all the way around the game. It is an expensive system and I have already had to return the product when I had the red light issue on the system. Hope someone knows if this issue can be fixed or what an alternative would be.
    Problem Solver:
  • 16 Answers
If your xbox box it's new I would take it back and get another one, becase you do probable have problems with your dvd drive and it will keep scratching the games. the laser on the drive doesn't work as hard when playing a music cd than when it plays a game or a dvd.
If you don't want to take it back, then play a couple dvds and if it reads then fine then you could try again. it shiudn't take more than ten second to read a game so if its taking longer just get it out.
Posted on Dec 27, 2008
When putting in Forza Motorsport 3 the console makes a lound noise, like the fan is on overtime when reading disc a lot louder than other games. Tried other games after and just low hum. Is it the...
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
  2. Go to My Xbox, and select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
Jul 18, 2011 | Microsoft Xbox 360 Console
My 360 will let me play a little bit of a game at a time. after playing maybe 5 or ten min or so it will freeze up. the last two times that it froze up it asked me two clean the disc, or contact xbox3660...
You specify the xbox 360 do you know what year model you have? If it as earlier model then likely you are running into system instability with many reasons for the error being possible.
Does the error only appear with one particular title or across your game library?
If it is just one game then attempt to install the game onto your hard drive and play the game after that. To install the game onto your hard drive you will need to do the following:
Notes
I am getting the error "this disc is unreadable" when inserting COD MW2 into my first xbox. When I insert the disk into my second xbox I do not have any problems playing it. I borrowed another...
I have actually had the same problem myself. First you should try removing your Hard drive to see if that is what was causing the problem. If that isn't it then clear the cache by going to: System Settings -> Memory -> Device Options (Press Y while you are highlighting the proper storage device) -> Clear System Cache Try to start the game after that and should it still not work then try to install the game to your Hard Drive by inserting it at the Dashboard, pressing Y to access "Game Details" then "Install Game". If none of this works then you may have a faulty disc drive which you would need to contact Xbox Customer Support about.
Jul 17, 2011 | Microsoft Xbox 360 Console
When I play Black ops it loads but never goes past the black screen after you press play game. I have an Xbox 360 white and I'm wondering is that the problem. When i took it to my uncles 360 it worked...
I have never heard this issue before. You probably have a lager issue then what can be resolved here and might face future issue in the future. Is this the only game you are having issues with?
Seeing that you mentioned you have purchased a hard drive then I would recommend you install the game to your hard drive and try play after that. This will resolve any issues possably of your disk drive possably getting hung up during gameplay.
follow these instructions to get your game installed on your hard drive:
Notes
Hi there my xbox 360 will play dvds/cds but will not play games it just says play dvd when a game disc is inserted in the console can you please help me thanks mr shane arnell
Sounds like the Xbox 360's disk drive is starting to fail. Knocking on the top of the Xbox (when its on its side) while loading a game can sometimes get it to work, but its better to have your Xbox repaired or replace.
Apr 19, 2011 | Microsoft Xbox 360 Console
Disc Grinding, Not Motor or Magnet Thing
I think the only option for you is buy a replacement drive off ebay (you want the same model doesnt matter about the FW version) swap the PCB of the drives over so the new one has your old PCB. The same thing happened to me but when I lubed the spindle the grinding noise went away for a week at a time, so I got fed up of constantly lubing it and bought a new one off ebay and swapped the PCB worked brilliant ever since. Hope this helps.
Paul
Apr 25, 2009 | Microsoft Xbox 360 Console
XBOX 360 grinding and having trouble playing discs
Hi the grinding noise is caused by your laser, the pickup unit needs replacing and your drive needs servicing too. we can repair this including all parts and return postage for £40 to your door.
returning to m$ will cost you a lot more and this is definately NOT covered by any of their warranties (unless its under 12 months in the uk).
we can provide you with a smooth error free drive with a brand new laser for just £40
www.fixmyconsole.co.uk
Apr 10, 2009 | Microsoft Xbox 360 Console
UNABLE TO PLAY GAMES
sound like the wormgear motor
is sliping or failing ether way
you may need a new drive with
a pc board swap .cost 40.00 D.I.Y.
May 03, 2008 | Microsoft Xbox 360 Console
Disc Drive
u need a new drive
Jan 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
136 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
