Question about Sony Playstation 3 (PS3) Console
Ps3 connection to the internet
Tried to connect ps3 to internet using ethernet cable have full signal and my computer is set up for file sharing and it says that it cannot obtain ip adress ive tried everything
  • 3 Answers
Are you sure that you got the right Ip ? Otherwise I would try to shut down the system and put all cables out and in again. If that doesnt help I am sorry and
Good Luck!
Posted on Dec 27, 2008
1 connected ethernet cable from modem to dynex hub in "uplink port", ran another ethernet cable from laptop to 2nd port on dynex hub and ethernet cable from ps3 to 3rd port and nothing happens. Please help...
If your trying to use this to share an internet connection.. sorry to say but it's not going to happen. The hub that you purchased will not handle the DHCP settings that need to be processed to share an internet connection.
Best advice... go back to Best Buy and smack the agent that sold you this and get a router instead. :D That's what you're needing to share your connection.
Oct 23, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
Ip address failed
  • In order to connect your console to the internet you will need the following:
  • Laptop with WiFi
  • Ethernet cables
  • USB cable
  • Video capture card
Below are the steps involved includind some additional information:
    File Sharing
  1. Step 1 Go to Settings in the PS3 menu and scroll down to Network Settings. Go to Internet Connectionmag-glass_10x10.gif Settings and select your wireless router from the list of available connections. If the router has security, you must input your password. Internet Connection in the Network Settings list will say "Enabled" once you are connected.
  2. Step 2 Link the laptop and PS3 together through a router if you have one. Connect both the console and computer to the router with Ethernet cables. This is needed for a PS3 with 40 gigabytes of memory and that does not have WiFi.
  3. Step 3 Connect the devices directly with a USB cable. Use one of the USB-style ports the PS3 uses for its game controllers. This requires a USB cable with two thin connector plugs.
    Connecting to a Monitor
  4. Step 1 Purchase an external video capture card for your laptop. This device will connect to the computer through the USB port and will have both composite and S-video connections.
  5. Step 2 Connect the capture card to your laptop. Insert its included CD-ROM into your disc drive and install the software on it that allows the computer to recognize the card's drivers and includes a video viewing/editing application.
  6. Step 3 Attach the PS3 to the capture card using the console's RCA composite cable. Open the video application and turn the console on to view it in the program's screen.
  7. Step 4 Locate and click the application's "full screen" button to enlarge the game screen to your full monitor. THANKS. MIKE
May 04, 2010 | Sony Playstation 3 (PS3) Console
How can I connect my ps3 to my computer modem?
Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection...
1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation.
2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this:
DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3
3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1).
4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window.
5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does.
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
NEED HELP connecting my ps3 to computer to share internet
You need to configure Windows 7 for internet connection sharing (ICS)
http://www.home-network-help.com/windows-7-internet-connection-sharing.html
Mar 28, 2017 | Sony Playstation 3 (PS3) Console
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Connecting ps3 via t-mobile web n walk
now then or you hav to do is plug it to your pc go to internet connection t mobile properties then advanced allow to share to other connections then plug your cable to your pc from your ps3 you might have to turn your windows firewall off or just change the settings if you dont want 2 turn it off
Dec 09, 2007 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wireless
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
Internet connection
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
