Question about Lanzar VIBE266 Car Audio Amplifier
Protection light on and no sound
Ok well i bought that amo about a year ago and i had a guy at best buy install it wire everything up cause i didnt want it to go bad on me...well about a week later the amp went into protection mode and i sent it in to get fixed cause it was under warentee...to make a long story short it turns out that the guy at best buy wired my 4 ohm rockford fosgate p3 (if it makes any difference) into a 2 ohm mono which from my understanding gives it more power but is hell on the amp...so now that its not under warentee, i was wondering if you know what part they would of replaced and would i be able to fix that myself...heres the parts number of what they replaced last time...(audio IC/TR c5198) (x2 which i presume means two of them)
thanks
Hgjkhkkhkg
Posted on Dec 27, 2008
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
Nov 25, 2013 | Sony KDF-42WE655 Television
Installing aftermarket stereo
Sounds like one of your connections are bad. Go through them again and be sure everything is secure. Also, definately check the fader and balance settings, could just be that the fader is set to front and balance is set to left. Also, why did you punch the first one?
Jul 20, 2013 | Audi Cars & Trucks
So i have installed my amp, epicenter, all wiring is done, hace great ground.. But once i turn my car on to sound check everything starts fine but after turning up the volume a bit.. My amo goes into...
It sounds like you have your gain to high. best way to solve this is by turning the gain way down to - or lowest number , then turn everything on and upto the volume you desire, then slowly up the gain. also avoid using bass boost, I agree it sounds great but it puts strain on the amp and shortens life in the amp. with the bass boost off, you can adjust others (not the gain) to get bass.
Hope this helps
Jan 26, 2013 | Car Audio & Video
The laser light is not lit
Replace the strip wire that connects laser pickup unit to main baord at first. If do not help, repalce the laser pickup unit.
Jun 13, 2012 | Sylvania SDVD8732 Player
Lg products ****. don't buy anything lg and you won't have to waste time reading this. i bought everything lg. the dishwasher motor broke, the microwave door had to be replaced because the circuit board...
Not to make it seem like LG isn't your problem, but there might be something that's common to all these units that is the cause. Power surges, spikes, and brownouts can all cause the things you describe. Appliances should be able to withstand problems with power, but not all are equally good.
My point isn't that you are wrong, I'm just suggesting that before you spend lots of money on new appliances, have a qualified electrician take a look at your electric wiring and make sure it's in good condition. It's cheap insurance (maybe $150), and if they find something, it'll save you a bundle on buying new again in another couple years.
Best wishes, and keep after LG. If the electrician says everything is fine, keep asking for supervisors and supervisors until somebody says they are the biggest boss there. Then write letters to the CEO!
Sep 16, 2009 | Washing Machines
We bought a refrige from Sears two years ago. And with the first one the light in the inside stayed on so much it melted the liner. So they replaced it for free. Now with the replacement it did the same...
Call Sears and see if they had a recall on your fridge. Just replacing the part is not going to do any good. Sounds like there is a problem with the wiring causing the bulb to overheat and melt everything. So just replacing the bulb and the plastic will not solve your problem if that doesnt work by calling them, then contact the BBB.com and Sears will have to to keep there status good make it right with you
Feb 19, 2009 | Refrigerators
No power to face of set
check the wiring harness (if used) for complete connection into the unit, or check all of the wires to make sure you didnt miss one while installing the unit. another thing to do might be to find a wiring diagram for your year, make, and model car and check all of the wires.
the guy at best buy who did mine effed it all up with which wires go where, but the rest of the job was pretty bangup. if you cant get it fixed yourself, i recommend them.
Aug 15, 2008 | Kenwood Car Audio & Video
Amp stuck in protection mode.
check to make sure your ground wire is attached to a clean metal surface no more then 18" away from amp. check all wires to ensure none are touching other terminal. all else fails remove one sub and see how it play, if its works great switch subs. could be a defective amp. if it is the amp and you payed for it with a credit card or bank card you can do a charge back from the bank to get your money back if the store wont replace it. thell the bank "you want to do a charge back cause it wasnt as discribed).
Nov 10, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Okay i have a problem hifonics brutus 1500 mono d class amp
well your amplifier is obviously going into protect mode,(i used to have this amp and it is awesome) anyway i would go through just to be sure and check all the power connections with a test light, remote wire, positive, and ground. and check the fuse to see if it is still good. you can buy a test light at wal-mart and any automotive store. if you stil have a problem then i would check to see if your running below 1 ohm on this amp. that would cause it to go into protect mode. if all this fails i would just go buy a new one.
Oct 07, 2007 | Hifonics Brutus BX 1505D Car Audio...
Lanzar VIBE266 Car Audio Amplifier Logo
133 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
