Question about Nintendo Wii Console
Make Wii remote#2 remote#1!
I lost wii remote#1. How can I get wii remote #2 to work?
You need to sync it . . . under the flap on the console where you insert memory cards, there is a red sync button, press that on the console, then on the remote, under the battery cover, there is also a red sync button, press that just after you done it on the console and it should sync.
Posted on Dec 27, 2008
Epic Mickey 2 wii on wii u remote and nunchuck problems.
Do you think it's the battery? Or maybe the back. If the wii loses power, either the game you are in will immediately pause or it will continue moving in the same direction you pointed it in before the wii lost power
Apr 23, 2014 | Video Game Consoles & Games
We bought a pro pack but lost the instructions to sync it to our wii. can you walk us through it?
You must sync the remote. To do this first take off Battery cover of remote.(leave batteries in) Then press the tiny red button on the front of the wii console next to the sd card slot for 2 seconds. Look at the back of the remote. In the battery compartment there is a tiny red button that looks like the one one the wii. Press it and they should sync. Now your remote should work.
Please rate.
Jan 01, 2011 | PSA Parts Limited Pro Pack Mini for Mini...
Lost communications to WII remotes and board
hi, my wii console works exept the little hand from the wii will not go on the screen, the remotes are programmed in and work fine so wondering what the problem could be? if its the sensor bar or something else and can it easily be fixed? thanks
Apr 20, 2010 | Nintendo Wii Console
Adding new controllers when original is lost
hello,
i have looked around for you and i beleive all you need to do is press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it.
and it should work like a charm to get you back to throwin some curve's in wii sports!!!!!
i hope i have helped and i hope it works!! let me know how it works
Jan 03, 2010 | Nintendo Wii Remote Controller
My handsets wont sincronise with the system, I have fitted new batteries
Follow this procedure:
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
* If multiple Wii Remotes do not work, or you only have one Wii Remote, a repair of the Wii console is necessary.
Oct 20, 2009 | Nintendo Wii Console
I lost my player 1 wii remote my others don't work.what do i do
open the battery cover on the wii remote you want to make player 1 press the red button while it is facing the sensor bar. Then open the memory card door on the front of the wii and press the red button on the top. the remote should flash a few times then it will be your new player 1 remote. You can only do this if you have 2 AA batteries in the remote. It will not work with the rechatgeable batterie packs because the remote must have power while you re-synch it.
Jun 10, 2009 | Nintendo Wii Console
Lost wii remote and need to know howtogetotherwiiremotestowork
When the Wii is on, you should be able to go into the menu to reset the remotes. Otherwise when you power them on press the home button and it should give you the option of resetting them as well.
Mar 28, 2009 | Nintendo Wii Console
Wii remotes lost connection with console
You need to open the small compartment on the front (located between reset and eject) were your can insert a sd card. Above the slot will be a red button labled sync. Press(maybee hold) the button and press the 1 and 2 buttons on the remote. This should get your remote working with your wii.
----John
Nov 09, 2008 | Nintendo Wii Console
Can't play with 2 players
Make sure you have paired both remotes to your Wii console.
Open the little door on the front of the Wii (under the disc slot), and open the battery cover of the Wii remote (but leave the batteries in).
Push the red button on the Wii (next to the SD card slot), then push the red button on the Wii remote (next to the batteries). You should see the Wii remote's lights blink.
Do the same for your other Wii remote.
Now on the bottom row of 4 lights on the Wii remote, one should have the first light lit, and the other should have the second light lit. You should also be able to see a cursor for each remote on the Wii Menu.
Apr 03, 2008 | Nintendo Wii Console
2nd wii remote will not connect with mario play 8
We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
This is from www.nintendo.com/wii :
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Dec 23, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
44 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
