Question about Toshiba Satellite M60 Notebook
Power could not be supplied to internal bluetooth module
How do i set the wireless communication switch to on
What do I look for to fix the Power seats and power tilt steering has no power
A control module ! Electronics The steering column has a tilt/telescoping control system that consists of an electronic control module capable of class 2 serial data communication, a steering column power assembly with positioning motor and sensor, and a steering column control switch. The multi-function lever provides for the control of the headlamp high beams, and the windshield washer and wiper.
The tilt/telescoping steering column in/out/up/down switch is an input to the driver position module (DPM). The tilt/telescoping drive motor is an output function of the DPM.
Steering column memory settings are stored in the DPM. The steering column position sensor is an internal part of the tilt/telescoping motor assemblies, and is an input to the DPM. The DPM uses the position sensor input when storing and recalling memory settings.
Same thing with the seats , electronic control module .
Battery positive voltage is supplied at all times to the memory seat module (MSM) through the battery positive voltage circuit from the POWER SEATS circuit breaker located instrument panel (I/P) fuse block. This voltage is used to power up MSM and also to apply power to the seat motors when commanded. Battery positive voltage from the TILT/TELE SW/MEM SEAT MOD fuse located in the body control module (BCM) fuse block that supplies voltage to the seat adjuster switch and the memory function switch, also supplies voltage to the MSM. The MSM monitors this voltage circuit in order to determine if battery voltage is supplied to the seat adjuster switch. The MSM is grounded through the module ground circuit and G301.
Body Control Module (BCM)
RH footwell, mounted to the toe board, behind the carpet
Nov 05, 2015 | 2006 Cadillac XLR
What is bluetooth phones
Hello
Bluetooth is a short range wireless communication method that allows a phone to communicate with a set of headphones, an earpiece, an in-car module (provides "hands-free"), an external loudspeaker, or any other bluetooth device by "pairing" the devices together so that the connection requirements are remembered and can be activated whenever the paired devices are within range of each other.
An example is perhaps easiest to understand. I have a bluetooth kit in my car which plays through the in-car stereo. As soon as I start the car engine and therefore give power to the unit via the ignition switch, it automatically finds and links to my Samsung Galaxy in my shirt pocket.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 27, 2015 | T-Mobile Cell Phones
I dont have bluetooth in my laptop.
some laptops come with bluetooth modules available some dont.
assuming the bluetooth module is avaliable:
  1. switch on you wireless adapter
  2. check for programs or utilities that managers your wireless
  3. check if the setting for bluetooth and set to on or enabled
  4. you might need to set it to discoverable if you need to search and and send some files to you lap
then assuming that Bluetooth module is not available:
  1. you need to buy bluetooth adapters that you will plug and play
  2. install the neccessary drivers and utility programs
  3. then follow the above steps
Jan 16, 2013 | Compaq Computers & Internet
Hi my new acer aspire 5732z does not seem to have a bluetooth connection any ideas where it should be
May I know whether the Computer is supplied with internal Bluetooth Adapter? If yes, have you enabled the Bluetooth switch or Wireless switch? Try reinstalling the Bluetooth Driver and change the bluetooth settings from the Control Panel
Jul 09, 2010 | Acer Computers & Internet
There is no bluetooth software in my system?
May I know whether the Computer is supplied with the Internal Bluetooth adapter? If yes, please turn ON the Bluetooth switch or Wireless switch in the Computer. You can change the Bluetooth settings from the Operating System provided Bluetooth software. Please open the Control Panel to view the Bluetooth application.
Jul 04, 2010 | Computers & Internet
Want to hook uo bluetooth
First switch on bluetooth (settings---bluetooth).
Start > Settings > Communications and Add new Bluetooth headset. htc will search bluetooth headsets and find it. it will ask you to enter bluetooth passcode, usually it is 0000. then finished and you have paired Bluetooth headset with HTC
Mar 26, 2010 | HTC Cell Phones
Acer 4200 wireless switch
I have copied a portion of the user manual that shows the location of the wireless switch which is on the front edge of the computer.
From left to right on the front edge of the lower portion of the computer (Not the display) The wireless switch button is the third switch from the right. Or just to the left of the power indicator light. These buttons are located in between the speakers. The buttons and lights are described below. a link to the download the complete user manual to PDF is located below.
# Icon Item Description
1 Speakers Left and right speakers deliver stereo
audio output.
2 Bluetooth
communication
button/indicator
Enables/disables the Bluetooth function.
Indicates the status of Bluetooth
communication.
3 3G switch/indicator Enables/disables the 3G function.
Indicates the status of 3G communication
(for selected models).
4 Wireless
communication
button/indicator
Enables/disables the wireless function.
Indicates the status of wireless LAN
communication.
5 Power indicator Indicates the computer's power status.
6 Battery indicator Indicates the computer's batttery status.
7 Microphone-in jack Accepts input from external
microphones.
8 Line-in jack Accepts audio line-in devices (e.g., audio
CD player, stereo walkman).
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Please let me know if I can assist you further with this question by replying to this message.
Brian
Jan 29, 2010 | Acer TravelMate 2300 Notebook
Wireless Printing set up
In order to print via Bluetooth communication with Macintosh, the following system requirements must be satisfied.
Computer
A Macintosh with an internal Apple Bluetooth module or a Macintosh attached D-LINK DBT-120 USB Bluetooth rev.B
OS
Mac OS X v.10.3.3 or later
In order to connect the Bluetooth unit and print via Bluetooth communication, the following steps are required.
STEP 1
Check that the Bluetooth unit is properly attached to the printer.
STEP 2
Install the MP Drivers.
STEP 3
Check the device name of the printer using the LCD.
STEP 4
Register the printer as a Bluetooth device using Bluetooth Setup Assistant.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
Bluetooth
I am having ACer 5500 Lapto Computer. I format my system and i installed XP professional. i installed all the driver softwares but the bluetooth device is not detecting, it show there is no bluetooth device check the device. How should i rectify the problem please help me. 5500 is consists internal Bluetooth.
Nov 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
NO WIRELESS CONNECTION
I am aboutsure about the question, but what i understood is wireless switch location
First close your laptop, then look the front view where the speaker is located, From the left
1.Speakers Left and right speakers deliver stereo audio
output.
2 Power indicator Lights up when the computer is on.
3 Battery indicator Lights up when the battery is being charged
4 Bluetooth communication
button/indicator (for
selected models)
Press to enable/disable the Bluetooth
function. Indicates the status of Bluetooth
communication (optional).
5 Wireless communication
button/indicator
Press to enable/disable the wireless function.
6 Line-in jack Accepts audio line-in devices (e.g., audio CD
7 Mic-in jack Accepts inputs from external microphones.
So your wireless switch is the 5th one from the left. Locate it and turn on the wireless, and try to connet to the router.
Try this, hope it may work,
Jan 27, 2008 | Acer Aspire 3000 Notebook
Toshiba Satellite M60 Notebook Logo
623 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
