Question about Miller matic 140 Mig Welding Package W/As 907335
Need wiring schematic for miller 140 wire feed welder
Looking for spool gun connector parts, part numbers, schematics. The parts directly associated with the mig machine itself. Not the spool gun. Miller matic 140 mig welder without autoset feature specifically.
  • 92 Answers
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
Have hard wired a spool gun to my mishto welder feed works gas works bur no power for arcing.
connect the + lead to the spool gun so that there is power at the end of the wire to make the arc
there should have been a user manual showing how to connect it into the system
try searching -- user manual for ( make and model of ) spool gun
Apr 25, 2018 | Miller Welding Tools
My welder won't feed wire it sounds like it's trying to energize but can't. A couple of times it fed through but wouldn't feed to weld so I had stick weld. What happens if the liner has a restriction?
first unscrew the tiny tip at very end of torch (can be hot)!! then try to feed wire thru handle,gently shake cable as you do helps to feed wire thru cable , if successful you have allowed the amps to get too high for the feed rate (slow) and melted the tip closed , these tips are replaceable from miller and are not expensive
Aug 09, 2016 | Miller Multimatic 200 MIG TIG & Stick...
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Millermatic 140 w/ auto set powers on but will not feed wire or arc
    If its a new unit its probably nothing. Miller makes good stuff. Open the side so you can see the spool. With the machine on, press the trigger for a second. Did the little wheel spin (trying to feed the wire) if it did then your problem could be kinked wire, **** on tip, or spring on small spool is loose and wire is slipping. Let me know.
    Nov 20, 2009 | Miller matic 140 Mig Welding Package W/As...
    Wire feed assembly for a Astro power mig welder 110
    go here and buy the parts i have one too, fix it and sale it!!!!! (JUNK WIRE FEED )
    http://store.daytonamig.com/wifeteas.html
    Jul 11, 2009 | Miller matic 140 Mig Welding Package W/As...
    Wire feed not working Miller 250 mig welder
    If the knob spins all the way around (and especially of it didn't always do that), it's broken. This could mean that the nut that holds the rheostat in place has come loose, or it could be that the wiper inside the rheostat has broken off the shaft. To find the voltage measurements, correct schematics, etc, I'd need to know the serial number of your welder.
    Regards,
    Carl
    Feb 22, 2009 | Miller Welding Tools
    Hobart handler 140 will not feed wire
    A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
    Feb 13, 2009 | Hobart Handler 140 Mig Welder
    Miller welder CP250TS
    You don't say why you need schematics. Most of the stuff that you need to know to install, use, and understand the welder is covered in the operator manual. You can get one at this web page.
    There is also a copy of the schematic diagram on the inside cover of most Miller welders. Please be careful if you're not familiar with high current power supplies, you could get hurt pretty badly in the blink of an eye.
    Regards,
    Carl
    Jan 17, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
    I have a miller 180 autoset that does not feed the wire
    If your welder is less than 3 years old your local Miller authorized service center will repair it for FREE. They can also check the serial number of your welder over the phone to see if it is still in warranty. For goodness sake DON'T tell them you've been mucking around inside the welder or they won't be able to help you.
    That said, if the welder spins the feed wheels without any wire between them it probably isn't the board. There is the switch in the gun, the board, and the motor and brake assembly all needed to feed the wire.
    Oct 18, 2008 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
    Miller matic 140 Mig Welding Package W/As 907335 Logo
    2,174 people viewed this question
    Top Miller Welding Tools Experts
    Steve Allison
    Steve Allison
    John Trevino
    wadingriver
    wadingriver
    Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
