Question about Motorola Mobility HS820 Consumer Headset
Can't hear with bluetooth
I got the HS820 paired with my phone but I can't hear anything. Is there anything I can do?
    President:
  • 1,257 Answers
That means the pairing is not successful.Follow the steps
1.Turn on mobile bluetooth and set the status to shown all 2.Tun on the bluetooth mobile and keep pressing the button on the  bluetooth for few seconds. 3.You will notice that light is continously ON and not blinking 4.Now find the device from mobile via search option 5 When it detect use this code 0000 to pair. 6.When the pairing is successful ,select option button and click connect.. 7.Now you should hear from your bluetooth..
Regards
Dilip Bagdi
Posted on Dec 27, 2008
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
When i try to pair it the bluetooth and my phone wont pair!!!The Bluetooth device is the HS820
Follow these steps to pair your phone with the bluetooth device.
Pairing
With the headset and phone close together:
1 With the headset off, hold the Multifunction Button until the LED remains on (about 5 seconds).
2 Perform a device discovery from the phone. For details on device discovery for your phone, refer to the phone’s user’s guide.
When the scan is complete, the phone displays the devices found.
3 Select the Motorola HS820 from the discovered devices list and confirm following the on screen prompts.
Action
4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
The device ID is now stored in the phone’s memory.
Pairing is successful when the headset indicator flashes rapidly.
If helpful, please rate this solution.
Thanks
Apr 12, 2010 | Samsung SGH-e315
Motorola HS820 - cannot hear anything nor can others hear me
It turns out it was the Blackberry's problem, which could only be solved by a 're-boot' - take off the back of the Blackberry, pull out the battery for 10 seconds or so, and replace it. The BB will 'reset' and all was fine then.
Feb 16, 2010 | Motorola Mobility HS820 Consumer Headset
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
Wont hook up to PS3
Alll it says in the manul under Pairing: Charge for 2 hours before use
Step1: When the headset is off, press and hold the mutlifunction button until the headset indicator turns on permantly
Step2: Perfrom device scan from the PS3 in this case.
Step3: Confirm Motorola HS820 in the list discovered by ps3 and confirm.
Step4: When requested to enter Passkey enter:0000
Jan 06, 2008 | Motorola Mobility HS820 Consumer Headset
Motorola hs820
you have to press and hold the button for a few seconds, it will then flash 3 times and then stay solid blue, this is now in pairing mode, get your phone to find the headset and then pair usually with the numbers 0000, then thelight will flash then it is paired.
Sep 30, 2007 | Motorola Mobility HS820 Consumer Headset
My Phone Does Not Locate My HS820 Headset
Try the following:
1) Make sure the HS820 is fully charged up.
2) Remove the battery and SIM card from your phone for about 1 minute and put them back in.
3) As soon as your phone is booted up, access the "find devices" function for adding your HS820.
4) Hold the HS820 button down until the blue light is solid.
5) Then do whatever your phone requres to "search for devices."
6) Here's the key: as the phone is searching for devices, PHYSICALLY TOUCH touch the HS820 to the phone.
I couldn't get my HS820 to synch with my new Blackberry Curve the normal way and ultimately got it to synch by going through this process.
Sep 11, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola HS820
the always on light mens that it is in pairing mode and wont go out until it has paired with a phone, if you wish to turn it off, press and hold for 3 seconds, it will then flash 3 times and then go off. Try pairing again by pressing and holding the button until the light stays on.
Jul 10, 2007 | Motorola Mobility HS820 Consumer Headset
Samsung e900 pairing
if you press the power button and hold until the blue light stays on the set is then in find mode, at this point use your phone to search for new devices and when it finds it it will see the HS820 and probably ask for a pin number this is 0000, when they are paired the blue light will flash and then flash intermitently from then on.
May 26, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility HS820 Consumer Headset Logo
193 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
