Question about Canon PC-940 Black and White Copier
MY COPIER KEEP FLASHING A LIGHT OF PAPER YAM BUT THERE IS NOT ONE I THOUGHT IT WAS OUT OF INK SO I GOT A NEW BUT IT'S STILL FLASHING LIGHT
  • SKFain Dec 31, 2008
    The paper jam light stays on but there is no apparent jam. the copier will not make copies because of the light.
  • 92 Answers
The copier have a paper jam on the left side on fixing unit or on right side .
or the copier have a paper sensor that does not move.
Posted on Dec 30, 2008
2 Suggested Answers
  • 126 Answers
SOURCE: COPIER PROBLEMS
Start by powering off the device and unplugging if from the wall. Let it set about 1 min and power back on. If the jam light is still on go to the directed area and make sure that an actuator, switch or sensor is not pulled out of position or covered with paper dust or a tiny piece of paper. If all is clear and nothing out of place you could have a bad senor, switch or actuator. The worst case would be a bad board.
Posted on Jan 04, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I have an Epsom SX115 the paper light is flashing but there is paper in it, and the ink light is flashing but there is ink in it, and the stop button wont work, so even if the cartridges needed replacing I...
Hey llstevetrish,
sorry to here of your printer issues. Have you tried to unplug it to clear what ever error there may be? I don't own an Epson now but you may try here: http://www.fixyourownprinter.com/forums/inkjet/59932#1
Good luck and hope the link helps.
Nov 11, 2010 | Epson Stylus Multifunction Inkjet Printer/...
When i turn the printer on the ink light and paper light are flashing back and fore and nothing works
You should check your cartridges. If one of them is empty, usually the printer won't print. Your cartridges have chips on them, and that chip determines how much you are going to print. Usually, when both lights are flashing, and nothing works, it has something to do with the cartridges.
If that is not the case though, please leave me a comment, as I would love to help!
Mar 07, 2010 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
ALL THE LIGHTS ARE KEEP FLASHING ON AND OFF
Unplug the printer from the power strip or wallk outlet for a few minutes.
Disconnect the printer from the computer see it it powers up normally, if so connect it to the computer.
If the lights are still lit, and the printer is brand new, and none of the suggestions helped, call the manufacturer as it is in warranty.
Good Luck
Feb 16, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Philips magic 5 primo machine doesn't send or receive
the green flashing light means your ink cartridge is empty
you need to replace this before you can send/receive
once you have installed new ink green light will go out
Jan 12, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
COPIER PROBLEMS
Dec 27, 2008 | Canon PC-940 Black and White Copier
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
Canon PC-940 Black and White Copier Logo
91 people viewed this question
old marine
old marine
