Question about Canon PC-940 Black and White Copier
COPIER PROBLEMS MY COPIER KEEP FLASHING A LIGHT OF PAPER YAM BUT THERE IS NOT ONE I THOUGHT IT WAS OUT OF INK SO I GOT A NEW BUT IT'S STILL FLASHING LIGHT
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Start by powering off the device and unplugging if from the wall. Let it set about 1 min and power back on. If the jam light is still on go to the directed area and make sure that an actuator, switch or sensor is not pulled out of position or covered with paper dust or a tiny piece of paper. If all is clear and nothing out of place you could have a bad senor, switch or actuator. The worst case would be a bad board.
Posted on Jan 04, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Paper in correct turned printer on red light flashing and will not print paper is blank when it comes out.
Red light flashing, do printing, paper blank out : ink low message. Ink level low, near to ink out level. But it just program, may be ink tank is out actually (no ink at ink tank). Refiil ink tank or replace w new one. Check Nozzle.
Jun 11, 2009 | Epson Stylus C46 InkJet Printer
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
ALL THE LIGHTS ARE KEEP FLASHING ON AND OFF
Unplug the printer from the power strip or wallk outlet for a few minutes.
Disconnect the printer from the computer see it it powers up normally, if so connect it to the computer.
If the lights are still lit, and the printer is brand new, and none of the suggestions helped, call the manufacturer as it is in warranty.
Good Luck
Feb 16, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Philips magic 5 primo machine doesn't send or receive
the green flashing light means your ink cartridge is empty
you need to replace this before you can send/receive
once you have installed new ink green light will go out
Jan 12, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
the copier have a paper jam on the left side on fixing unit or on right side .
or the copier have a paper sensor that does not move.
Dec 27, 2008 | Canon PC-940 Black and White Copier
I have brought a replacement cartridge (black) for the Epson D92 stylus printer I folowed the usuel steps and sucsesfully printed 4 or 5 b&w pages now the printer does not seem to except the cartridge...
This may or may not work on your model
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
The Protection Counter referred to above prevents you from printing once the printed pages counter reaches a predetermined threshold.
If this doesn't work, let me know.
Regards,
Worldvet
Nov 11, 2008 | Office Equipment & Supplies
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
Canon PC-940 Black and White Copier Logo
62 people viewed this question
old marine
old marine
