Question about Motorola Mobility L6 Cellular Phone
L6 White Screen
When I Turn on the phone it shows white screen and get's off.Is there other way to fix it berofe i flash the software.
Tnx for helping.
    Problem Solver:
  • 9 Answers
There is the problem with your software.
install new software from motorolla repaire center.
Posted on Dec 27, 2008
  • Anky_rocks
    Anky_rocks Dec 27, 2008
    there is the problem with your software.
    install new software from motorolla repair center.
Why doesn't it charge?
Hi Stacey, The links below are youtube videos showing how to fix white screen, CHEERS
Fix for Android Tablet White Screen Issue
white screen on cell phone YouTube
Apr 07, 2016 | Alcatel Cell Phones
Tip
Screen problems on phones
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
When a phone screen is blank, has a white screen, etc, there are three things that could be the cause;
  1. Bad/defective screen and the solution is screen replacement
  2. Software/Virus problem and solution is to flash the phone
  3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
on Oct 12, 2010 | Cell Phones
My screen on my lg phone stopped working and only turned white but then goes back off and then doesnt work what should i do?
Software/Virus:
Flex problem
I hope this helps.
Good luck.
Apr 23, 2011 | Cell Phones
Nokia 3110 white display
whats u r problem
Mar 02, 2011 | Cell Phones
N95 black creen
Software/Virus:
Flex problem
Good luck.
Aug 27, 2010 | Nokia N95 Cellular Phone
My Nokia N70 shows white screen only when turned on and will not respond to any input ..how can I reboot the system..my PC shows no connection and will not recognise my N70
hi,
there are two kinds of white screen in n70 ,the first one is because of damage LCD (glass screen) ,defective display driver (small chips that makes the display works) and the other one is corrupted software...in damage lcd the phone will detected by computer because its software is still working...so ,the problem of your N70 im sure is the second one ,corrupted software....your phone needs to reprogram,and need to go to a nokia care center to fix you problem...i hope ,i will help you ,thanks for trusting fixya...
Jun 15, 2010 | Nokia N70 Cellular Phone
My nuvi 750 shows a white screen only
You are going to have to send it in to manufacturer for a software re-flash.. Just a bug that some phones get randomly. It is annoying, I have had this myself but that is the only cure.
Aug 31, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Screen flashes white
I have your phone, my phone has always done this. It is a self test, the phone will quickly vibrate and a white screen will appear then disappear. The phone will then boot. This is a standard operation of the phone.
David
Jun 26, 2008 | Sony Ericsson V630i Cellular Phone
White screen
Try flashing your phone's firmware with the Nokia sftware updater.
http://www.nokia.co.uk/link?cid=PLAIN_TEXT_52635
Mar 21, 2008 | Nokia 6280 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
