Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Gas fireplace pilot flame won't stay lit.
I have a GTI fireplace mn. 4000- gvd-hsi. I Follow starting Instructions but the pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
I changed my thermocouple on my fireplace,it still wont stay lit
Thermocouple keeps the pilot lit.
Thermopile keeps the burner lit.
Please specify what won't stay lit...
If it's the burner, you may need to change the thermopile as well.
If the pilot still won't stay lit, you will want to make sure that the pilot flame is large enough to completely engulf the thermocouple and keep it hot. If it's too small, you may need to take some compressed air and blow out the pilot hood to remove any blockage.
Dec 18, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have an Insta Flame Canadian Fireplace Manufacturing Inc. gas fireplace, installed in 1990. The problem is that when I light the pilot light, it will ignite, but it will not stay lit when the knob is...
sounds as though you need to get the thermocouple(copper wire that sits in the pilot flame) replaced, check first to make sure it is tight at the gas valve end, as they can loosen over time due to expansion and contraction.
Sep 06, 2011 | Heating & Cooling
Gas fireplace wont stay lit- it is a sealed unit so can taccess the pilot or gas holes in the logs. is it safe to remove glass panel?
Yes, removing the glass is safe, if you do it carefully, so as not to break it. Put it well out of your way, after removing it. In fact, removing it is the only way to access and service the Pilot Assembly and the Burners.
If the pilot won't stay lit, there are several things that can cause this on a Direct Vent Gas Fireplace:
  • The direct vent on the outside of the house is block or clogged.
  • Wind is blowing back through the direct vent, blowing out the pilot.
  • Low gas pressure
  • A dirty pilot.
  • The thermocouple and/or Thermopile (part of the pilot assembly) has failed.
If you can provide me with the make and model number of your gas fireplace, I may be able to furnish you with an Owners Manual, that will help you to continue to troubleshoot the problem.
Hope this helped you.
Apr 29, 2011 | Heating & Cooling
Have a GTI Insert Replaced the thermo coupler . Now the pilot light stays lit but when the fireplace starts it will only go for about 30 seconds then you hear a click and shuts down pilot and all.
It sounds to me like you have a bad flame sensor.Luckily most of the time they are pretty easy to change. If you have your manual it will show you the physical location of flame sensor. Usually 1 or 2 screws holding it in place. Remove screws and unplug wires to remove sensor.Install new sensor and hopefully you're in business. Thank you.
Nov 22, 2010 | Leisure HOMEPRIDE Electric Fireplace...
The fan will blow but not in heat mode. The gas heater sounds like it wants to work but there is no heat.
Hello my name is Heath it will be my pleasure to assist you. The problem is probably with the ignition. Check the pilot if its a standing pilot or the hot surface ignitor if it has a HSI ignition If you ohm the hotsurface ignitor and it doesn't show resistance the HSI is shot. If its a standing pilot try lighting the pilot if it lites and doesn't stay lit then the thermocouple could be bad its the rod that sits in the pilot flame easily replaced with a universal replacement that can be found at most hardware stores.
Apr 25, 2010 | Honeywell Programmable Thermostat Heater
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
The pilot is off and I don't have the manual. How do I start the pilot to turn on the logs
You will need to find the gas valve. Open up the lower section of the fireplace and look foe a small cube of aluminum with a knob on it that says On-Off-Pilot. Turn the knob to the Off position by lining up the word with a small dot or line indicator on the body of the gas valve. Then turn the knob to the Pilot setting. You will know when you are in the correct setting because you will be able to depress the knob into the gas valve body. Hold the knob depressed and click the larger red button. It will snap so don't be startled. Continue to hold the knob in while looking between the logs for a blue flame. If you don't see one, keep snapping the red button. Once you see the flame, continue to hold the knob depressed for 30 seconds or so. Release the knob and make sure the flame stays on. If it does not, repeat nthis procedure and hold down the knob for 45 seconds. If the flame continues to go out, you need a new thermocouple. Once the flame stays lit, rotate the knob to the On setting. The main burner should start within 15 seconds.
Nov 26, 2009 | Leisure HOMEPRIDE Electric Fireplace...
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Oct 13, 2009 | Desa International Heating & Cooling
Heating & Cooling Logo
1,660 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Steve
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
