I am having difficulty connecting my PS2 to my bose lifestyle18. I have a projector setup, using all composite video connections. I have a PS3 connected via HDMI to the Projector and a digital optical audio output for the sound.
My issue is how can I connect PS2 to the Bose lifestyle with the setup I already have ? I can sort out the siund, how can I get video, since all video outputs are used ?
Except all I would like to know is how to connect a ps2 . PERIOD> there are no open components on back of TV. On the Bose system AUX and VCR are open.Except all I would like to know is how to connect a ps2 . PERIOD> there are no open components on back of TV. On the Bose system AUX and VCR are open.
You can't post conmments that contain an email address.
These components are meant to be compatible with each other, providing a seamless audio and video experience. Here's how you can connect them:
Connections to the Media Center:a. Soundbar Connection: Connect the Bose Lifestyle 135 soundbar to the MC1 media center using an audio cable. Depending on the available ports on both the soundbar and media center, you might use an optical audio cable, coaxial audio cable, or another appropriate audio cable type.
b. Subwoofer Connection: The Bose Lifestyle 135 subwoofer is a wireless subwoofer, which means it connects wirelessly to the media center. During the initial setup process, the subwoofer should automatically pair with the media center. Follow the instructions in the user manual to ensure proper pairing.
Speaker Setup:
The Bose Lifestyle system, including the MC1 media center, typically uses Bose's ADAPTiQ audio calibration technology. This technology helps optimize the sound based on your room's acoustics and speaker placement. Run the ADAPTiQ calibration process as outlined in the user manual to ensure the best sound quality from your system.
Remote Control:
Ensure that the remote control provided with the Bose MC1 media center is properly programmed to control both the media center and the soundbar. If needed, follow the instructions in the user manual to set up the remote control for seamless operation of all components.
Audio and Video Sources:
Connect your audio and video sources (such as Blu-ray players, cable/satellite boxes, game consoles) to the appropriate inputs on the Bose MC1 media center. This allows you to route both audio and video signals through the media center and enjoy them with the soundbar and subwoofer.
Power On and Configuration:
Power on the Bose MC1 media center and ensure that the soundbar and subwoofer are also powered on. Navigate through the media center's on-screen menus to configure the audio settings, input sources, and any other preferences.
Testing and Adjustment:
Play different types of audio content to test the sound quality from the soundbar and subwoofer. Adjust the volume, bass, and other audio settings to your preference using the remote control and on-screen menus.
Remember to consult the user manuals for both the Bose MC1 media center and the Bose Lifestyle 135 soundbar for detailed setup instructions and troubleshooting tips. If you encounter any difficulties during the setup process, Bose customer support can also provide assistance.
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
If you use both s-video and composite (yellow) video at the same time on the bose system, it thinks you want to use the component adapter (which is included with the system). Just use one or the other. But if this is still in black and white (it may because the system still thinks you're using the adapter) just press "system" on the bose remote, and go to "video" and then "video connector" If video connector says "Component", try to change this to "composite + s". If this doesn't let you change it (it may not) then restart the system by unplugging the DC power cable for 30 seconds and re-connect it.
I hope this helps.
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
SOrry for your plight, the Bose staff are correct, they do release occassional firmware updates via a DVD or a CD throught their costumers mailer. If you are not part of this mailer, you may go to any Bose service center and request the latest update disc for your Lifestyle 18-II system. Udpates should be able to help you sort out your problem.
Your Bose system doesn't lead sound trough hdmi.
You must connect the optical cable with your lifestyle.
Change the sound connectionsettings in the menu of your ps3.
You also need to assgn the optical connection in the setup menu of the lifesyle. e.g. optical=aux.
Try the settings setup and adjust the brightness, video format, or video black level. If you're using component connections then adjust the video output. You can scroll system setup through the remote control settings button.
