Question about Acer Aspire 5500 5570-2609 Laptop
Internet problem My brother change network from singtel to starhub .He can access to the internet to his laptop n desktop.But my laptop cant access to internet.The network connection signal shows as very good.my only problem here is cant access to internet.wht could b the problem ?
  • malligaipatt Dec 28, 2008
    i guess i still cant solve the problem
    President:
  • 1,179 Answers
Rerun the network setup wizard on your computer. Make sure all computers, printers, and routers you want to use in the network are turned on and that an internet connection is present. Once you do this your problem should be fixed. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 27, 2008
I cant connect to wifi please help
Right click on the internet icon in bottom toolbar open network and sharing set up a new network or set up a new router or access point it will then search for any internet connected devices.
Right click in bottom toolbar select toolbars desktop this will place Desktop >> in the toolbar click on >> then control panel Network and Internet , internet options all control panel all items internet options connections set up a new connection.
Make sure the never dial a connection circle is ticked.
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=420860 - Issue0_1
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=420860 - Issue0_3
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=420860 - Issue0_5
Jul 19, 2013 | Dell Alienware Area-51 Alx Gaming Desktop...
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
I Have 3 PC's. 2 desk tops and 1 laptop. My desktops were working fine but laptop wont load internet. It says it connects to M10 router but cant find internet. Reset everything and tried again, Same...
Title: Can not access internet by other laptop
Open control Panel and go to Network and Internet Connection.
Open it and select Network Connection
After that you see your networks , select and Right Click on it and go to Advance Tab
In Advance tab you just see a option like "Allow me to share my network"
Click on that option , apply and ok
After that 1 dektop connected with another by LAN and Laptop connected with 2nd desktop By use of LAN cable
it call Series Connection.Like--1st desktop--->2nd Desktop--->Laptop
Otherwise Bring a HUB and You can access internet
Now you can access internet on both laptops
May 07, 2011 | Cisco Valet Wireless Hotspot (M10)
I have a Virgin modem & d link DIR 615 router. I am connected to my desktop via ethernet cable which connects to the internet ok & works fine. I wish to connect my wife & son's laptops...
Hi
while your computer connect to the internet so the connection is good ..
but in other laptops please do that change IP mode to the DHCP Mode or give IP in the same network
try to click repair
Apr 25, 2011 | D-Link DIR-655 Wireless Router
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Mt6227
ask at chinamanuals.com - they can send you MMS and GPRS settings for each provider worldwide.
Jul 27, 2009 | Siemens M56 Earbud Hands Free Headset
Friend used our pin number to access internet
You should not have given your friend your pin number. He has access to your Internet account and has locked you out.
Contact your Internet Service Provider and explain what has happened and get them to change your account login password. Then follow their instructions to setup your Belkin router.
Jul 25, 2009 | Belkin (F5D7230-4) Router (587009)
Networking
Your router internet settings should depend on your ISP connection type. If you are on DSL, either your setting is PPPoE or just obtain IP automatically. If you have a username and password from ISP, select PPPoE and specify your username and pw. Check on the internet/WAN status if it says "Connected" and if it has Internet IP address.
Your modem should be plugged in to the internet port of the router while both your computers should be on plugged in to the LAN ports (numbered ports).
You may contact your router manufacturer for step by step assistance on the router setup. They should be able to restore your connection.
Apr 09, 2009 | Edimax BR-6104K Router (br6104k)
Can't access workgroup over wifi using USR 9108
You need to set up sharing and network on the desktop.
Mar 17, 2009 | Computers & Internet
Problems with home networking between desktop running XP (wired) and laptop running Vista (wireless), using DSL broadband (PPPoE) internet connection, Westell 6100 modem/router & Linksys Wireless-G WR
Hi MissGarbs,
Based on your post and description, it would seem that your problem is caused by:
1. having 2 routers on the same system;
2. Both routers performs DHCP server function; and
3. Both routers use 192.168.1.1 as default IP Add.
Your problems are:
a. laptop has no internet access only local network; and
b. you cannot access the router to make changes.
A possible solution. Pls back up your configurations first before attempting changes (or log them down somewhere so if needed you can revert back).
A. Power off and remove all connections to the LinkSys WRT54GS, set it aside for the moment. The objective is to verify/establish Internet connection.
Connect your desktop PC via LAN cable to the Westell 6100. Boot your desktop PC, right click on the networking icon bottom right side in your system tray, click on Status, click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right):
tick "Use the following IP address"
Enter values as shown below -
IP address: 192.168.1.4
Subnet mask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS servers: 68.238.0.12 & 68.238.112.12
click on OK, OK, Close.
Power on the Westell 6100, give it time to sync and connect to your Verison. .In the desktop PC, open a browser. Verify that your desktop have access to the Internet, do it on a few sites. Should you have no internet access, pls seek assistance from Verizon tech support. You need not mention the LinkSys nor the laptop since you have as of the moment a single PC attached directly to the Westell 6100.
If it is all green & go, power up your laptop and boot to Windows. Remove the LAN cable at the back of your desktop and connect it to the laptop's networking port. Do the same configuration ("Use the following IP address") to the networking/LAN card of your laptop.
IP address: 192.168.1.5
In the laptop open a browser. Verify that your laptop have access to the Internet, do it on a few sites. Should you have no internet access, pls seek assistance from Verizon tech support again. You need not mention the LinkSys nor the desktop since you have as of the moment a single laptop attached directly to the Westell 6100. (This is of course assuming that your laptop has a networking port)
If both the desktop PC and the laptop can now connect albeit individually to the Internet, the LinkSys may now be inserted into the system.
B. Disconnect the LAN connection of the laptop to the Westel 6100 and connect it to one of the 4 LAN ports at the rear of the WRT54GS; do the same with the desktop (use another LAN cable). The LinkSys for the moment need not be connected to the Westell. So in effect you have 2 units connected to the WRT54GS. Do a hard reset on the WRT54GS, with the power on, press on the small reset button at the rear of the unit. Allow it to reinitialize. Open browsers to both laptop and desktop. Type "192.168.1.1", password is "admin" and the username is blank, verify that you can open the LinkSys Web Configuration Utility. On either the laptop or the PC desktop (assuming both can access the same page), on the setup page of the LinkSys Config, change your Internet Connection Type to "Static IP",
Internet IP Address 192.168.1.2
Scroll down to Network Setup,
Change IP Address to 192.168.1.3
Disable the DHCP Server (You can have at any given time only 1 instance of a DHCP server, either from the LinkSys or the Westell, but you can also have NO DHCP server if you are using static addresses.)
Click on Save Settings at the bottom, exit, and close. Verify that the LinkSys can be accessed from any of your browsers by typing "192.168.1.3", if no; go through the procedure again very carefully. If yes, proceed to change the Default Gateway of both the laptop and desktop PC from 192.168.1.1 to 192.168.1.3, all other configurations stand.
In your laptop, right click on the WiFi networking icon (bottom right of System Tray). Click on Status, click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right):
IP address: 192.168.1.6
Default Gateway: 192.168.1.3
Verify that you can access/connect/ping 192.168.3; 192.168.4; 192.168.1.5; and/or 192.168.1.6 from either the laptop or desktop.
If yes, we can now connect the LinkSys WRT54GS to the Westell 6100. Remove the LAN cable attached to your laptop. Verify that you can still access/connect/ping 192.168.3; 192.168.4; 192.168.1.5; and/or 192.168.1.6 from the laptop even without the LAN cable since you are now connected via WiFi.
If yes, connect that LAN cable to the Westell 6100 LAN port, move the other end from 1 of the WRT54GS ‘ 4 LAN ports to the WAN likewise at the rear of the LinkSys.
Verify that you can access the Internet from either computer. At this moment, you have not assigned a security method (WEP, WPA, MAC Filter). Your choice as to what security you want implemented but offhand I would suggest the simplest, MAC Filter since any other would affect speed of your connection.
Additionally, you may want to enhance you browser connection. In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Normally (and perhaps easier for some) would be using the DHCP and not using static. Experience has shown me that static proves to be more stable especially if WiFi is concerned and in your case, only 2 PCs.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 05, 2007 | Linksys Wireless-G WRT54GS Router...
Acer Aspire 5500 5570-2609 Laptop Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
