Question about Sony RM-VL900 Remote Control
"AMP" button on Sony RM-VL 900T stopped responding
The AMP button has stopped responding on my Sont RM-VL900T, most probably from overuse. Is there a way of re-activating it? I have taken the remote apart and cleaned whatever I can but has not resolved the problem. Your assistance will be appreciated. Ander Cool
  • andrecool23 Dec 30, 2008
    Please close call, tooexpensive. Thanks
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    New Remote is solution as old one is exhausted.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
To reset all functions for a Component: Press and hold [S] until the green indicator lights. All Component Select buttons will flash. While holding [STOP], press the desired Component Select button.
Posted on May 09, 2009
Need front panel screen for sony klv26bx310 tv.How much?
You will need to contact Sont or a Sont Agent. Its probably more expensive than buying a new TV
Mar 13, 2016 | Sony KLV-26BX310 BRAVIA Multiysystem LCD...
What's the difference between sony rm-yd028 or rm-yd065?
To most Sony remote controls, P+ / P_ & Vol+ & Vol -- ; buttons will work, except for other buttons will work. The difference between the Sony remote controls you mentioned here too will differ to these function. http://electronicshelponline.blogspot.com/
Oct 19, 2014 | Televison & Video
How do I program the buttons on sony RM-EV100?
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Oct 22, 2012 | Sony (RM-EV100) Remote Control
Chunghop rm-309es code for Sony
Check these codes:
0128 0013 0002 0071 0380
Direct Code Entry
May 12, 2012 | Universal Remote Control Remote Control
Trying to program sony rm-v202t for dav-sb100
Direct Code Entry
Apr 29, 2012 | Sony RM-V202 Remote Control
I have an "naxa tv" and I really need the code for
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the S button.
  3. While holding the S button, press and release the POWER button
  4. Release the S button.
  5. Press and release the appropriate component button for the component being set up.
  6. While pointing the remote control at the component, press and release the CH + button.
  7. Press and release the POWER button.
  8. NOTE: Repeat the previous two steps until the component responds. It may take 70 tries until the correct code is located.
  9. When the component responds, press the ENT button.
Jun 03, 2011 | Sony RM-V202 Remote Control
I have an sony rm-ez2 and i want it to work with my orion Model #tv1934 whats the code or will it work
As far as I can tell, Sony doesn't have any codes for Orion TVs. You can try searching through all of the codes in the remote. Turn on the TV, press and hold the Set button and then press the Power button. Release the buttons. Then press TV button (component button). Press the CH+ button followed by the Power button. Repeat the CH+ and Power combination until the TV responds (powers off, changes channel). Then press ENT. Check if the TV responds to the remote on other functions. If it doesn't repeat the steps from press and hold the Set button.
This can take up to 70 tries.
Alternatively, try a replacement remote for the TV or a USB programmable universal remote. http://www.remotes.com/store/orion/tv1934.html is a substitute remote that should handle all of the functions.
I hope this helps.
Sep 06, 2010 | Sony RM-EZ2 Remote Control
Sony RM-VL900 Remote Control Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
