Code : M3
Now, I am facing problem on Minolta EP5000 apear message on the screeen "Preventive Maintenance Time Please Call technical rep. and provide the following code"
CODE : M3
TEL :
How to clear that message...
Anybode can help me please...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
I think that is for waste toner bottle it is full just clean or change it .and reset all counters .MIAN AKHLAQ
Posted on Dec 31, 2008
Minolta CF3102 questions
After resolve the problems,or change the supply to refer the message ,the tehn rep message displayed automattically.
Aug 02, 2014 | Konica Minolta Office Equipment & Supplies
How to remove on screen preventive maintenance time m5
there is no M5 preventive maintenance only M2 and M3 please conform
May 10, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Message is Service call 2A, help
that we are call preventive maintenance, you need to exchange drum dev'r consumable etc, then auto atdc just acess the tech rep.
Oct 14, 2013 | Konica Minolta Magicolor Office Equipment...
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
Preventive maintenance time code:M2
just enterto tech rep mode stop 0 stop 1 then select funtion then find maintenance counter then reset the maintenance counter
Nov 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta Ep4000 show CodeM2 /code 00040
This is just a message shown when counter is reached for preventive maintenace. If everything is working fine, u can just ignore it.
Mar 29, 2009 | Minolta EP4000/5000 CS/PRO Copier
Set the copier into Tech. Rep. mode by pressing the following keys in this order : utilty meter count stop 0 stop 1 then from the menu select counter then select Maintenance select the conter then enter anew value from the 10-Key pad
Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
May 12, 2008 | Konica Minolta bizhub C250 All-In-One...
Minolta Di151 Error Code C-13
The trouble is that Minolta did not provide a chart of error codes in the user manual; mostly error code issues would require a technician to repair anyway -- or at least somebody trained to do preventive maintenance. If you have a routine repairman, or if you have My Konica-Minolta access, you should be able to get more information that way. Other things to check:
  • Is a preventive maintenance due?
  • What was the unit doing before it threw the code? Was it making copies? Of what quality? Did it stop in the middle or finish a run?
  • Are you using good quality, dry paper? This was posted in December -- might you be having static problems due to dry air?
If you're in the United States, you can check Konica-Minolta's Sales/Service Locator for a local repair outlet. Otherwise, you may need to contact Konica-Minolta directly.
Dec 26, 2007 | Minolta Di151 All-In-One Laser Printer
151 people viewed this question
k24674
jasbo
jasbo
