Question about HP DeskJet F380 All-In-One Printer
Keep reinstalling software
I have downloaded the software for my printer and it works fine. However when I plug it into my USB it reinstall a copy. So if I plug it in 5 times I end up with 5 copies . How do I stop that?
  • 7 more comments
  • claytonb2003 Dec 27, 2008
    Windows says installing device driver.
    I let it run it's own installer but it keep asking for CD which I say cancel.
    It then says finish and I am able to use the printer and scanner in fact all accessories but a printer is installed copy 1 or 2 or 3 as the default printer. Once I unplug it does the same thing again.
    I am running Windows Vista and have to move around with my laptop but my printer is set
  • claytonb2003 Dec 29, 2008
    Good morning. I have changed the device settings and disable manual duplexing. That has solved the problem. Thanks for all the support.
    I am not familiar with roaming profile in Vista although I am online and uses IM. What is roaming?
    Thanks for the feedback. Do appreciate the support.
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Have you setup a roaming profile in Vista? That would clear things up. But, I will look into a recipe I can send to you so you can do this unless you are familiar with roaming profiles. Just give me a bit of time.
    One of the kids was here from College and had to spend three days cleaning the laptop of viruses. She just headed back. I'll have to do it all over again on Spring Break. Next laptop she buys herself.
    I'll look forward to solving this problem for you.
    Worldvet
  • Glenn Rogers
    I'm going to be offline for several hours but will pickup on your problem as we continue to get the preliminary questions out of the way later.
    Wrorldvet
  • Glenn Rogers
    Are you removing the USB plug as you only have one and or not enough to spare for your other devices?
    Which Operating System are you using?
    Worldvet
  • Glenn Rogers
    (Question 1)
    Does this occur when Windows itself, states New Hardware Found?
    (Question 2)
    And if so, do you let it run its own installer also?
    (Question 3)
    What is it you have done at this point?)
    Here to Fix It,
    Worldvet
    Guru:
  • 859 Answers
Sounds like Vista did what it was designed to do on paper. I was a bit baffled as Vista is smart enough to recognize when you are roaming.
Thanks for using FixYa.
Worldvet
Posted on Dec 29, 2008
  • Glenn Rogers
    Glenn Rogers Dec 29, 2008
    Roaming was designed for the mobile worker who can travel among a network with wireless access points and switch off from one access point to another. In its early concept 'roaming' made sense for the phrase and it has stuck. The whole ideal was to have it seamless, meaning no action needed from you the user or IT to keep you, your profile working. As new devices come within range of your access, privileged card (Credentials) allowed, they would automatically become available, ie. printers. In the home area network, you as an Administrator have elevated privileges. (Although, this can get you into trouble if you poke around and change settings.) The issue with your printer, I don't see this as a problem but a very valid concern and a major annoyance. We see these all the time with the Windows Operating System.
    Thanks for playing your hunch and saving us both the time to discover it in the long run.You have good intuition and I would encourage you to trust it.
    If you look under C: there is a folder called Users. Here you will find your personal folder and under this is the Roaming folder. All of the entries and actions of Vista are 'transparent' to you (and should be) where in the past it meant IT had to create these profiles for roaming and users would poke around and set thing on tilt. That was what I was looking to discover that you then dismissed from my concerns. That there was a problem, that you had set a control to manual.
    With Roaming working correctly you should be able to take your laptop to work, Starbucks and return home without having to interact with any access controls other than logging in and providing a password. Your system should adjust and adapt automatically. This is 'Roaming' in theory. Hopefully it will fully mature as designed. Eventually, you should be able to travel by car and have wireless access the Internet by jumping off the nearest wireless card to you, and then the nearest card to that and continually hop by meshing will all other mobile devices around and in use. This will all occur in a reserved band of the device and heavily encrypted. This is called Wireless Mesh and what we will all be using late next year. When wireless mesh is fully working and mature Roaming will reach its idealistic goal setup 10 years or so ago.
    The author Arthur C. Clark envisioned all this in a SciFi novel in the late 1960s.
    Come back here to any of us when you need a hunch verified or you are concerned you may be about to do something you may regret, concerning your system. Or, if you just need plain help with your hardware. I focus on printers a lot and always have. I have four personal computers and two laptops. All these are running various versions of Windows and Linux. If you don't hear from anyone shortly you may always call on me. When I can't be of immediate assistance I can and will ask a colleague to come in and confer with you on my behalf.
    Its been a pleasure to assist you.
    Thanks for using FixYa, regards,
    Worldvet
My 6530 works OK as a copier but not as a printer or as a scanner. I suspect that the USB interface is defective.
It is could be a software related problem. Software called drivers are needed to run the printer. The drivers for your printer can be found on the CD disk that came with your printer. They can also be downloaded from the manufactures website, click their downloads/support button and select your model of printer. Download and install the drivers for your specific model of printer and for your specific version of Windows.
Take care!
damnor01
Aug 13, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
First of all, on Dymos you need to use original Dymo roll,.
Dymo rolls have a tag at the back, non original ones does not have it.
Before reinstalling driver you also need to run the dymo uninstaller utility that you find at Dymo website.
I will post the links for download.
Oct 03, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
I cannot launch lexmark productivity studio nor can I get my X2650 to scan. It will print and copy
Hi.
If you cannot start the Lexmark productivity studio, then the software may need reinstalling.
Reinstall the software using printer disk, or download from Lexmark website.
Also test using a replacement USB cable. A too long or defective USB data cable may cause the AIO not scanning.
If you have misplaced printer disk, follow instructions on link below to download drivers:
How to install a Lexmark printer when the...
Dec 11, 2009 | Lexmark X2600 InkJet Printer
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
LexmarkX5495 won't scan....can you help?
go to www.isohunt.com and download driver detective with key. Install driver detective. And let it to search for the drivers your system needs to operate any hardware. When it searches the drivers for your MFP then install it.
cheers
Dec 07, 2008 | Lexmark X5495 Printer
Won't work
Leave the printer on but unplug the power cord and USB cable. Wait 30 seconds and plug printer back in. Once it has finished coming on and initializing reconnect the USB cable. Try to print - up and working?
Assuming that the issue is software first uninstall the current drivers and then you can download and reinstall from the hp website. Just select your OS and then pick the most recent full feature software and drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&lang=en&cc=us
Aug 06, 2008 | HP DeskJet F380 All-In-One Printer
My Brother copier printer DCP-IIOC, will copy but won't print, in fact the computer won't recognise the printer, the usb cable is fine, what is wrong or can you help me please?
Try this :
First check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Apr 25, 2008 | Office Equipment & Supplies
Must Reinstall to Print
Most USB printers need to have the printer driver installed before you connect the printer to the computer, did you install the printer this way?
Also, check and see if it is the default printer.
If those do not work:
1) Turn off the Terminate and Stay Resident programs MSCONFIG in VISTA.
2) Disable HP device discovery service.
3) Uninstall the All-In-One software.
4) Turn off firewall and antivirus.
5) Reinstall the latest software for the All-In-One.
Hope this helps.
Please let me know how this works for you.
Jan 30, 2008 | HP DeskJet F380 All-In-One Printer
HP L7580 All in One Device driver reinstall on reconnecting thru USB cable
Everytime I turn on my home computer my HP Photosmart C4180 reinstalls everytime. I constantly have (Copy 1) (Copy 2) etc each time and have to keep changing the most recent as my default. Anyone know how I can solve this PLEASE!?
Oct 30, 2007 | Office Equipment & Supplies
HP DeskJet F380 All-In-One Printer Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
