Question about AEG 24 in. Favorit 40630 Free-Standing Dishwasher
AEG 40630 -top and middle lghit are flashing
When I'm turn on the machine the top and middle signal light are flashing and the pump working for some time and stop.
  • 192 Answers
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
Posted on Jan 19, 2010
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Aeg
Here is a link to the manuals site - I suggest you search by PNC number (you should find it on the label somewhere)
http://www.aeg.co.uk/Support/Manuals/
Apr 09, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Aeg dishwasher will not drain
The washer has a drain motor in line with the outlet pipe. The motor must turn when in outlet mode. This motor has an impeler that turns at high speed to pump out water in the outlet mode. The motor could be faulty or the lelectrical push on connectors to the motor loose. One can remove the motor and coonect it directly to the mains voltage for a few seconds to check if it spins (also make sure that nothing is blocking the impeler from spinning).
Oct 24, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
My dishwasher AEG FAVORIT keeps beebing and not working it flashes with a arrow and stright line? it stoppted half way through
The arrow straight line meens end of program. However the flashing lights do indicate an error codeas per the handbook. This could be the ati flood device (polystireen float / micro switch) at the bottom of the machiene indicating a water leak. This device puts the washer in pump out mode and nothing els works until the error has been rectified.
Sep 19, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Jun 14, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Upper basket spray arm
Have you checked that the cover for the water inlet at the top where it connects to the spray arm is attached? It could have worked loose. Just re-attach and your spray arm should "miraculously" start rotating again!!
Aug 21, 2008 | AEG 24 in. Favorit 40630 Free-Standing...
AEG Lavamat E1050 End light blinks 5 times.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
(Companies just want you to dump the machine & buy another, its keeps them in business)
Jun 01, 2008 | AEG Lavamat W1050 Front Load Washer
Toshiba plasma tv 55hx96 has flashing lghit problem
I have a red flashing power light on with no picture. I tried turning it off again same red flashing power light with no pic.
Mar 10, 2008 | Televison & Video
AEG 24 in. Favorit 40630 Free-Standing Dishwasher Logo
581 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
