Question about HP (322118RB21) Networking Switch
Hp channel ethernet
Hello
i have switch hp procurve i will make channel ethernet between 2 switches
i did the command ( interface 25.26)# trunk 25,26 trk2 lacp
but it is reading speed 1 G
you could tell to me what is the configuration between 2 switches
thanks
  • Anonymous Mar 29, 2014
    password
    Problem Solver:
  • 8 Answers
The speed of the link will not change when you trunk 2 or more ports together. Trunking is meant to spread the bandwidth across more then 1 link; but be aware, if you watch the traffic going across the trunked ports you may see a majority of the traffic crossing 1 link. That's because the switch uses an algorithm with the source and destination MAC address to determine which port the traffic will take. Adding a 3rd port to the trunk may help spread the bandwidth across more links.
Posted on Feb 10, 2009
How to configure VLANS and Tagging
https://m.youtube.com/watch?v=krE16IRIHw4
Watch this video for switch port access . You will need to be in global config interface mode.
Jun 05, 2016 | HP ProCurve Computers & Internet
Cannot access web interface
I'm going to assume you can get in the command line interface. Go into the command mode (type "config t" with out the quotes ) then type "ip http server" press enter, type exit to get out of command mode and then "write memory" to save your configuration. Remember, vlan 1 on the switch MUST have a IP address for you to be able to access the web interface.
Jan 03, 2014 | HP ProCurve 4208vl-96 (J8775A) 96-Port...
I want reset the factory default of my switch HP Procurve 2510G
To reset using the CLI, run the command "erase startup-config". When prompted, say yes to reboot and that will restore the procurve switch back to factory settings after it starts up.
Mar 08, 2011 | HP ProCurve Switch 2510G-24 24-Port...
Do I need to have a 10GE interface in order to stack 4 x 2824 20-port together?
no, you can use a 10/100/1000 port to link the switches together. Make sure you program the same VLANS on the switches and TAG all the VLANS on the switch port you use to link up.
Dec 21, 2010 | HP ProCurve 2824 20-Port Gigabit Ethernet...
My HP j8707 fiber module keeps dropping out and i must re-seat it everyday in my switch
Have you applied the latest firmware? or contacted HP support? HP support can be reached by calling 1-866-my-procurve.
Dec 15, 2010 | HP ProCurve 5400zl 4-Port 10Gb Ethernet...
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
HP (322118RB21) Networking Switch Logo
105 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
