Question about Samsung HCM4216W 42" Rear Projection Television
Replaced bulb and converge problems
I just recieved a broken samsung tv with a broken green bulb. I bought a new bulb online installed it and now that problem i am having is that the automatic convergence wont go past 25%. First i checked the new green bulb and as i looked in it i saw bubbles. Is this normal? Secondly i just tried to manually converge and i got pretty dag gum close but still not a professional job as this is the fist time i have ever taken apart a tv. Also whenever i try to do automatic converge it starts with green boxes goes to red boxes, hits 25% then restarts and never shows any blue. Any info would be helpfull on this problem i am having as i am completely new to the tv repair thingy.
  • Joshua Minoda Apr 21, 2007
    ok thanks for the info. also is it normal for the green to not be able to become all the way in focus? i tried moving the wing nut and it wont focus all the way
    Scholar:
  • 77 Answers
After replacing a Picture tube convergence/geometry allignments can be quite extensive and if they're not fairly precise the sensors for the auto conv. can not be calibrated therefore your auto conv. not working as you described. The key is usually the geometry start with the green lines and get them as square as you can then align the red/blue. Since the auto is not going to blue that often means the blue is to far out and the sensors are not picking it up.
Posted on Apr 21, 2007
  • josh vannoy Apr 23, 2007
    the wing nut loosens the lens and allows it to turn the wing nut by itself does nothing, also there is an electrical focus inside the TV. I would also be a little curious about the tube you got online often there are many types that may work but not quite perfectly.
I buy a new tv, samsung led tv. the problem is that we cannot connect the sound from tv to reciever
I bought a new ford electric car.
I am trying to install my Sony XYZ stereo in it but it doesn't hook up.
What do I do?
Ok, now we've isolated the problem in the structure of your question.
Without knowing a single thing about WHAT samsung LED tv you have, nobody can really help you.
Please be much more specific about the TV and how everything is hooked up and what it's hooked up to.
Feb 21, 2011 | Onkyo TX-SV454 Receiver
Purchased a new bulb for our Samsung HL-T4675SX DLP TV in October. Less than 3 weeks after the bulb was installed, the TV would not turn on and the three indicator lights on the front of the TV came on,...
ballast failures are not that common in general. i would suspect the color wheel before the ballast. do you hear a whirring noise when the tv is trying to turn on. sometimes the color wheel will not spin correctly and the tv will not start as a result.
Dec 23, 2010 | Samsung HL-T4675S Television
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Tv is getting power (flashing green light says so) pix never comes up and now the lamp light is flashing red. HELP the set is not very old. what should I do?
Need to replace lamp in TV as lamp seems dead/ broken and will be replaced.
Lamp replacement procedure is written in user manual and it is very easy.
Thanks.
Sep 28, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I just bought a new lamp for my samsung tv because the tv just want black,I JUST REPLACE THE LAMP a year ago to the date, i went to the store and just install it and it still does not turn on? so i called...
Steve The part you are inquiring about is called the ballast, It is a small (say 3" x 8" ) circuit board that attatches directly to the bulb via the two pronged leads coming off the bulb. On this set you'll have to take the back off to get to it. Once you do, you'll see it right infront of the optics block, just a couple screws will loosen it. There is a white and black power line and a sleeved reciever line connected to it. Get the model number off your ballast and go to shopjimmy.com rivervalleyelectronics.net or ebay and replace. If I remember correctly. There are several compatible ballasts for this set. Rule of thumb though, is that just because it looks the same doesn't mean it is. Call samsung, they will also sell you the newest, latest and greatest ballast. You can just ask them for a part number too and then shop around. Good luck.
May 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Bulk Life
Identifying the correct lamp code
Before placing an order online, you must identify which lamp code you need. The lamp code is located usually on the left side of the TV
http://fixyourdlp.com/blog/?cat=4
Jan 16, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HCM4216W 42" Rear Projection Television Logo
78 people viewed this question
Jerry Greenberg
Jerry Greenberg
