Question about Car Audio & Video
Fitting a Kenwood car stereo to a 2003 Toyota Hilux ute, all works well until aerial lead plugged in, then immediately the fuse blows that feeds park lights, dash lights, instruments etc. Car stereo works when aerial plugged in, fuse blown Could you please help me
    Problem Solver:
  • 11 Answers
The vehicle chassis ground or negative is opposite to the stereo. The aerial is vehicle chassis ground (earth), when touched to stereo results in direct short. If the Hilux is positive ( + ) chassis (earth) and the stereo is negaitive ( - ) ground, there is the short. If this is the problem, either replace with a compatable stereo or compatable vehicle.
Posted on Nov 07, 2009
New battery - battery is drained in the morning.Replaced voltage regulator. Disconnected aircon. Still drains overnight. Ute will start and run with full battery but it drains overnight.
Easyest thing to do is pull one cable off your battery. Start pulling fuses and each time touch the cable to the battery post. When you find one that reduces the spark drastically that is the circuit to investigate.
Jan 06, 2017 | Toyota Cars & Trucks
1996 toyota hilux
A rubber mallet is the trick, there is no tool. Even a stick of wood in a pinch. A soft blow or two should break the seal.
Apr 18, 2014 | 1996 Toyota Hilux
Toyota 2007 hilux ute changed battery radio does not work
If you have an aftermarket radio there is probably a wire going directly to the battery and that wire has a fuse. These fuses are very sensitive. Fuse or Wire.
I hope this helps.
Oct 21, 2013 | Car Audio & Video
Park lights dont work on hiace once i put in stereo
did you blow the fuse hooking up the radio wrong
Apr 26, 2012 | 1995 Toyota Hi-Ace
Parking lights will not work, fuse keeps blowing
have you recently installed a stereo yourself or someone done it for you,a common issue it using the wrong power feed from the park lights and over drawing current.
Sep 26, 2010 | 1993 Toyota Paseo
Wiring diagram for a toyota hilux 92 ln106 ute fried my wires trying to replace the loom need a diagram for wire colours
bought new alternator and battery. This fixed the dash lighting up like a christmas tree. Park brake still stays on. However, there is no lights when driving at night in the dash (unable to see speedo, revs etc) and no light to interior light, original clock or anything. Any suggestions????
Sep 16, 2010 | 1992 Toyota 4Runner
My electric aerial on my toyota hilux surf 3l automatic will not work , were can i find the fuse to stop the noise the motor keeps running as if it is trying to raise it
If you remove the plastic mud guard cowling under the wing you will be able to unplug the motor feed there. You will need to open up the spool chamber anyway as a bit of the nylon rack that pushes and pulls the antenna will have broken off and been lodged there.
Toyota should be able to sell you a new mast which simply screws on from the outside.
Mike
Aug 05, 2009 | Toyota 4Runner Cars & Trucks
Kenwood krc 479r
If there was no spark and wires hooked up wrong in the first place, your player should work if you find the PWR lead and the Remote lead and ground. Then speaker wires +) and (-
Sep 25, 2007 | Kenwood KRC-479R Cassette Player
Car Audio & Video Logo
199 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
