Question about Toshiba 57H81 57" Rear Projection Television
I want to take the screen off but i cant get the back off
I have a blotch on the bottom left corner of my tv and i would like detailed instrutions for removal of the screen and cleaning.
  • aboreeda Dec 27, 2008
    i need vedeo card to toshiba laptop R205-55800
Unplug TV, let it set unpluged for maybe a half hour or more (Just for safety) Pop off the speaker covers in the front of your TV, then remove the four screws under each cover, this will will remove the bottem face plate between the two speaker covers, then under that you find (I think four) more screws to remove just under the screen. Now if it is a BIG screen find someone to help you slide the screen up about two inches so that it will be released from the hooks on the inside. The screen is not at all heavy ( less than 5-10 Lb's) just flimsy and aqward. The screen is just a plastic frame holding two very thin plastic screens, one is a magnifing glass the other is vertical lines. If you must remove these from the frame,then as you remove the screen frame from the TV lay it face down and then remove the screws from the inside of the frame, Pay close attention to the way they come out if you put either one of them in backwards it will distort your picture and you will have to do the whole thing over again. The whole thing should only need a philips screwdriver and a half hour of time. GOOD LUCK.
Posted on Dec 28, 2008
Have a dark blotch on bottom right of screen. What is this? Transported in the rain and fear water got through carefully wrapped plastic. Help
It's possible the mirror has dome dust on it from jostling during the move. W dried water spot will do it too. The front screen will come off by removing the screws on the bezel. Be extremely careful cleaning the mirror.Any scratch by a cleaning cloth (never use paper) will permanently ruin it.
Nov 02, 2014 | Akai PT5492S 54" Rear Projection...
KF-50WE610 blotch of color on screen
Either dust/dirt inside (unlikely but possible) or a damaged optical light engine--Google the model number with "problems" etc.
Apr 17, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Bottom right corner has blue line blotches on screen most of the way across from right to left.
This is a Optics engine failure, Call sony to see if the warranty they extended on this model is still in effect.
If not then the the only way to resolve this issue is to have the optics engine replaced..
Nov 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Black blotch on bottom of screen
if you can take the screen out , then use some dish soap,rag and water to clean the black blotch
if that don't work you may need to use something a little stronger , but not enough to hurt the screen
please rate a fixya and I'll be happy to assist you in the cleaning process and care of the screen
Nov 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
I accidently held a magnet up to my TV screen and its busted up. How do I fix it?
Magnets and projection screens do not mix well. When you say `busted up` it could mean a few things.
If it means blotches of color on the screen
-Caused when your projection TV becomes magnetized.
-Use a strong magnetic coil and make circular motions around your projection TV screen starting on the upper left corner.
-Increase the size of the circles you're making until you've covered the entire screen. Slowly move away from the screen; continuing to make circular motions with the magnet.
-When the magnet loses contact, the color blotches should be gone.
hope this helps
Oct 08, 2008 | Televison & Video
Locked tv
I'm having the same problem. My screen is blue with a red lock in the bottom left hand corner. None of the buttons work except the on/off button on the television.
Sep 14, 2008 | Haier HTF20R21 20" TV
Sony Trintron KV-36HS500 TV color distortion
Sounds like the set is out of degausing, you will need someoen with a degausing coil to come and fix it. Should take all of 10 seconds and cost $100 or less. Let me know if you need more help.
Sep 11, 2008 | Televison & Video
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
Screen is filled with a circular Red/Green/Blue pattern
The problem will be with the de-gausing circuit, this de-magnetises the tube when the set is switched on from cold, this is a fault you will need to get an engineer to look at ie, not a D.I.Y repair.
Mar 05, 2007 | Samsung TXR2675WH TV
Toshiba 57H81 57" Rear Projection Television Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
