Question about E-Machines eMachines Desktop PC
EMachine will not turn on.
I received an eMachine T2865 desktop computer from a relative and she said she checked her email then powered the computer off and unplugged it all and put it in bags and gave it to me.  I got it and plugged everything in to the back plugged and then hit the power button on the front panel and nothing happened.  I can plug it into an outlet and then depending on which setting the switch is on 115V or 230V there comes a humming noise from the power box.  115V the humming is higher pitched and 230V a lower pitched hum.  I took out and removed the cover but everything looks in place.  My problem is every think look fine and like it should run but nothing does none of the fans will spin and none of the LEDs will illuminate. If I plug in an USB device they will not power on either.  So in short when I plug the computer into the wall outlet nothing happens no lights no fans no real sound except the humming from the box that the power cord plugs into, no sounds from any of the drives.  What is wrong? How can I fix it? How much will it cost me?
  • 51 Answers
Sounds like the power supply is faulty. Power supplies are very dangerous to try and repair, even for qualified technicians. I would also suggest not trying to plug it in or turn it on until the new power supply is in place. Faulty power supplies have been known to cause motherboards to permanently malfunction. Note: researching your issue, I came across several forum posts with complaints about emachines and their power supplies. The best way to solve this problem is to purchase a new power supply. If shopping online, www.tigerdirect.com and www.newegg.com are two places that specialize in PC hardware. A 400-watt power supply would probably more than do the trick for you. The cheapest one I found was $18.00. Make sure the power supply is compatible with your motherboard before you buy.
Posted on Dec 27, 2008
I need an illistrated guide to show me where to connect all hardware connection cables to the t2865 motherboard
http://www.retrevo.com/support/eMachines-T2865-Desktops-manual/id/14680ci368/t/2/
Jan 28, 2014 | Computers & Internet
T2865 chipset series
Which one is on the manfacturers site for your computers make and model?
Get onlineand got to www.google.com In the google search box type: "EmachineSupport" or "Gateway Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Chipset drivers.If the site shows more than one, use the one with the latest date.
Apr 30, 2012 | eMachines Computers & Internet
Green turn on button will not come on just orange lite. green button don't turn on at all nor will computer boot up. model T2865 bought in 2007
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 22, 2011 | E-Machines Emachine T2865 Power Supply...
Specs and pictures for a t2865 emachine computer
ok, you may look the motherboard manual:
1) set USB from page 14
2) set the front panel four connectors look from page 12
the manual reference :
http://www.lurkhere.com/~nicefiles/AU31_manual.pdf
hope help you fix it.
May 15, 2009 | E-Machines eMachines Desktop PC
Need owners manual
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2865
Mar 05, 2009 | E-Machines T2865 PC Desktop
Emachines t2865
Most Monitors. Have A Seperate Power Cord.
They vary in shape and size. 2 pin 3pin et,c.
Have a good look at the back, and check. you should have a power connector socket inlet. And a cable out socket, to connect Monitor To Sound Card On The Back of the Desktop.
These can be located on the back underside of the monitor.
if in doubt search for your monitor make and model on the net, and try to get some instructions.
hope this helps Mike.
Feb 17, 2008 | E-Machines eMachines Desktop PC
Identity of front panel wiring
what u meen front out in mic in headphone out ? or u meen the wires to plug into mobo
Jan 23, 2008 | E-Machines eMachines Desktop PC
Unit will not turn on
Our experience with that model has been defective motherboards. You can replace the board with a generic board if you cannot find the emachine board. You might have to reload Windows if you do.
Aug 14, 2007 | E-Machines T2865 PC Desktop
E-Machines eMachines Desktop PC Logo
141 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
