Question about SanDisk Sansa e260 MP3 Player
Not Working Okay I dropped my sansa in the water but it still works all that don't work is the screen and it doesn't do anything when I try to connect, the blue wheel just turns on. Is there anyway to fix it? Everything works fine I can still listen to the songs that are still on it but I can't delete or put anything else on it... because when I connect it doesn't show on the computer.
  • Anonymous Jul 31, 2008
    one of my brothers dropped my mp3 sansa e260 in milk but it only got wet halfway adn i took it out fast adn i opened it and dried it and now when i turn it on only the blud wheel turns on
    will it eventually work after drying out completely from the inside?
  • 0123456 Jul 31, 2008
    my little brother accidentally dropped my sansa e260 but it only got wet halfway and i took it out right away and opened it and i dried it but when i turn it on only the blue wheel turns on
    will it eventually work after it drys out completely from the inside?
  • 8,596 Answers
Cannot fix water damage - sorry
Posted on May 24, 2008
It as stopp working dont light up
Have you tried charging it? Maybe the battery is dead. Have you dropped it? Has it gotten wet recently?
Nov 19, 2011 | SanDisk Sansa Clip MP3 Player
1996 Dodge Caravan 3.8 V6 ...the turn signal don't work. It used to work on some warm days. Sometimes I had to wiggle a little bit the relay and it works. Now, its just don't do anything. Fuses...
you may have a second flasher unit , one for the emergency flashers and one foe the turn signals, some Caravans do . if yours doesn't happen to be one of them, you have a short in the switch itself, and will need to remove the steering wheel to replace it,, be careful, and follow the instructions for air bag safety when working with anything near the air bag,, remove the neg battery terminal first ,, then the positive,, and wait 10 minutes before doing anything else, this gives the system to discharge . when your done, hook up the battery in the reverse order
Sep 29, 2011 | 1996 Dodge Caravan
My ST500 samsung digital camra's touch screen is not working, but everything else does perfectly is there anything i can do to fix this? I don't understand why it doesn't work it has not been...
you have a bad camera. If your camera is still under warranty, I will repair it for 35.00. If it is out of warranty, then I will fix it for 165.00
call Continental Photo, 718-268-6440 Mon - Sat 10am - 6pm, ask for vic
Jul 31, 2011 | Cameras
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
Sansa Fuze wont work with home stereo
The Sansa doesn't play music through the USB port. You can connect the Sansa to your stereo via the Sansa's headphone jack.
Feb 22, 2009 | SanDisk Sansa e250 MP3 Player
Screen Blank- can't even reset
thats what happened to my ipod there really isnt anything you can do. i really know how you feel sorry!
Dec 30, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250
Take the screws out of the back, take the battery out then put it back in again. This worked for me.
May 02, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa m250 With Broken Screen
Users Manual is here; http://sandisk.com/Assets/File/pdf/retail/Sansa_ug_Eng_m200.pdf Page 26 has your answer. Best of Luck.
Sep 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
89 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
