Question about Indesit W 123 Front Load Washer
INDESIT WM12X WASHER HAS POWER THE DOOR LOCKS BUT NO WATER IS GOING INTO THE DRUM CHECKED THAT WATER PRESSURE OK BUT WONT EVEN DO A SPIN WHEN SELECTED FOUND THAT THERE IS POWER GOING TO INLET VALVES DO YOU THINK IT COULD BE THE VALVES
  • ralphyred Feb 18, 2008
    I have the same problem, machine sets off like it is working (lights flashing), but no water coming in. Cannot even use any other setting. Have cleaned out the pipes to remove possible blockages but still no results. What could this be?
  • 67 Answers
Brushes in your motor almost certainly, put your meter across the motor you will find a open circuit failinf that your control module could be damaged
Posted on Jun 25, 2007
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Water keeps clicking of after 5 sec same with draining water and drum wont sprin
Hi Robert.
If the machine fills with water and cycle starts but it does not spin and drain, then possible problems are drain hose, drain filter, pressure switch and less frequently pump.
Before advancing to spin the timer board performs a test on drain part of the cycle, stops the drain and checks the door lock. Drain system, pressure switch and lid switch are all parts that if defective may cause no spin.
The first part to be tested is the drain system. This must be checked regardless of the fact that the pump is working. If there is blockage, residual water in the drain system or water flowing back from drain hose may cause the washer not detecting that drain is complete, and not advancing to spin.
Disconnect power and check the drain system, accessing drain filter and hose connected to the drain pump.
In most front loaders this is accessed removing the trim at the base of the front side of the appliance (under the door), and rotating the filter cap counterclockwise. The filter should be located behind the trim at the base of the washer.
Top loader usually offer access to pump either from back or from the bottom of the appliance. In some case (eg.Kenmore top load) you have to lean the machine forware to gain access to the bottom part of the unit, where the pump is located.
After opening the pump hose cover be prepared to collect a good amount of water. Keep a container at hand. Ensure that power is not connected before starting.
Also double check drain hose at the back of the appliance, and check that the elbow height is as prescribed in manual. Incorrect drain hose settings may result in syphoning, that means water is flowing back from drain hose into the washer tube. This may result in no spin.
After performing the check on the drain system test washer again. Sometimes removing eventual blockage in drain pump may fix this kind of problem.
If the pump is draining, but drain doesn't complete, and if there is no blockage in drain lines, a parts that may be causing the no-spin problem are pressure switch and door latch switch.
The door latch switch is checked by electronic control before advancing to spin. The door switch is tested running a cycle with the door switch contacts jumped. If the model has a lock motor more testing is needed. In that case the switch is tested ensuring that the lock motor impedance reads according to specifications and energizing the lock motor.
If the drain stops always at same point and cycle does not advance replace also the pressure switch. The pressure switch detects water level and determines when drain is over and when to advance to spin. This part is difficult to test in full, the part is not expensive and it is usually replaced without testing. Pressure switch is a common failure causing no spin. If drain is OK, then either pressure switch or lid switch/lock system is usually responsible.
If the above is OK , with top loaders you need to add to the list the problems related to motor and transmission. In front loaders, check problems related to motor and motor control unit. Such problems will be near to the end of the troubleshooting list. Check them before deciding to replace the electronic control.
Always disconnect power cord or trip the circuit breaker before performing maintainance operations.
If you need to contact a qualified technician, call the phone number listed on the owners manual.
To find parts give me the model number or click on the link below, select distributor and enter your model number.
Parts and diagrams
Regards.
Ginko
Dec 04, 2011 | Washing Machines
I have a indesit wm12x I putted on pre-wash setting and the dial won't stop turning and I try to put it on rest/stop but won't unlock the door for me to take the clothes out! Any help please!
It's doing that because it is unable to drain all of the water out of your washer I suspect ;-0)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 06, 2011 | Indesit W 123 Front Load Washer
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Users manaul for indesit wm12x washing machine
when i put the washer on programe 8 washer starts ok then then programe selector knob just carries on going round only way to stop isto turn of power
Nov 14, 2009 | Washing Machines
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
Washing machine washing and rinsing ok but no spin at all.Any suggestions please
90% of the time you will find there will be no spin condition if there is still water in the tub. Remove water completely and if you feel confident, pull off the plastic pressure switch pipe on the drum and select the washer to spin and drain or if you can, just spin. If spin now works, remove pump and check for restriction or blockage.Reassemble.
Sep 24, 2009 | Indesit W 123 Front Load Washer
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
247 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
