Have a ati radeon 9250. loaded catalyst driver. admin/system tools recognize the card in a primary and secondary instance. both say they are working properly. when i plug into the vga interface I get no picture from my new lcd. i have no dvi cable. how can i get a video signal from the card?
  • 3 more comments
  • jhwang02879 Dec 31, 2008
    I am the OP. Using a vga to vga cord.
    LCD is PnP and did not come with a driver. Using XP driver.
    The MB has an on board video card. The monitor works fine in analog mode connected to the on-board interface.
    When I plug into the ati radeon 9250 video card and restart the computer I get no picture. If I plug onto on-board, I get the picture again. No need to restart.
    Haven't tried the DVI cable yet. Will post after I've tried that.
    Many thanks in advance. :)
  • Ben
    Ben May 11, 2010
    Can you test the monitor on another PC to ensure its not the monitor that is not working.
    Also, you could invest in DVI cable since this could (a) fix the problem since the VGA cable could be broken and (b) DVI quality is better. Cables are not expensive.
  • xpok7 May 11, 2010
    Are you using a VGA to DVI converter cable?
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Have you tried installing your LCD driver?
  • 24 Answers
Leave the card in there and try reinstalling the software. that should do it.
Posted on Jan 01, 2009
  • 281 Answers
Some monitors have a analog/digital switch. Check you documentation to see if your monitor is of this type. If it is, it might be as simple as switching to analog instead of digital.
BTW, If your card only has VGA (the blue plug) then using the DVI adapter (the white plug) will not likely improve visual quality.
Posted on Dec 31, 2008
  • Vern Haynes
    Vern Haynes Dec 31, 2008
    One other thing to check: Some of these graphics cards need external power to function. They will not work without it. I am not aware of any 9250's that have this requirement, but it is worth checking.
    Beyond that:
    The fact that the onboard graphics work when your Radeon does not limits the problem to one of two possible causes:
    1. The Radeon is dead (most likely)
    2. The AGP slot on your mainboard is bad. (less likely)
    Although I prefer the ATI cards (like your Radeon) for picture quality I have had really bad luck with the AGP variety.
    If the card was purchased new and is less than a year old, you probably have a warranty that is still in force.
    If you tell me the brand name of the card I can give more information on this.
    If you have a spare AGP card laying around, try swapping it out. I would bet that it will work.
    Otherwise, if you don't play games or anything on this PC, you may want to just remove the Radeon from the system altogether. With your onboard graphics working, you should be OK.
Computer video card swap?
Hello there!
Advantage is fairly possible.But the main thing that blocks people from getting full performance is,the power supply of your pc.
The new graphic card requires a little more of power supply to run better.You might wanna upgrade your PSU.
Cheers,
Aldo.
Feb 05, 2013 | ATI Computers & Internet
Well i put in graphic card ATi radeone 9250 agp 128 mb and then i instaled latest drivers for it including catalyst,and when i start game...any game..it crashes and i get error from catalyst center that it...
Hello
Uninstall All drivers and software for ati card. Take card out.Put card back in. Reboot pc.Reinstall drivers.I dont think the 128 mb cards Came with a fan.The 256mb did.
All the same,check your pc fans are working and clean.Also disable any onboard motherboard Graphics.You will need to do this in the bios.
Possible card was not seated right in agp slot,or drivers were corrupt.
Aug 16, 2011 | ATI RADEON® 9250, (128 MB) AGP Graphic...
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
Aug 07, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
Hi i got a radeon 9250 graphic card 128 Mb can it be work in window 7 or is that any diver for it to work with window 7. Pls email to bernardyanrenhao@yahoo.com.sg
You dont need any special driver. The windows7 update will include the updated ATI driver.
Anyway, if tou need any additional driver, goto
www.ati.amd.com
and download "Catalyst" driver
Aug 11, 2010 | ATI RADEON® 9250, (128 MB) AGP Graphic...
I can't get the catalyst to work. it keeps on saying i'm not the administrator.. etc
Ok. you are working on a limited account first create a admin. account from control panel if you have you should log in from there and install catalyst
Aug 08, 2010 | ATI RADEON® 9250, (128 MB) AGP Graphic...
I use ati 9250[256] for vista,but i cannot use my
Follow this link and get the latest catalyst drivers for your card.
http://support.amd.com/us/gpudownload/Pages/radeon-prer300-xp.aspx
Mar 05, 2009 | ATI GECUBE GEC-R9250-D3H WEDIO CARD RADEON...
D3D malfunction
ATI does not like drivers installed over top of it's self. Weird I know. So uninstall through your control panel. If the uninstall fails download and run.:
http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
After a reboot install the new driver & Catalyst control center.
Jan 02, 2008 | ATI RADEON 9250, (256 MB) PCI Graphic...
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
