Question about Intel Core Duo T2600, 2.16 GHz Core Duo (BX80539T2600) Boxed Processor
It will not turn on
I have replaced the mother board because i had a bad video card and before i did that it would start but now i started once or 2 times and then now it will not start at all
but with the old motherboard it would start and every thing but i did not use it for like 1-2 moths and now i dont know what it could be wrong could it be the motherboard battery ?
  • 4 Answers
You can choose corect mother board like old type with vedio card
Posted on Jan 03, 2009
My lenovo s10-2 no displayed on the screen when i turn it on. i see the fan working
1. Possible bad video card ( on the mother board)
2. Loose video cable (internal)
3. Possible bad hard drive possibly needs replacement.
Jul 15, 2011 | Lenovo Computers & Internet
My Gateway FX 7026 goes "Black Screen" upon start-up and nothing happens.
The video is out.If you have a video card,replace it.For now you can run graphics off the mother board.To do that.Turn the computer off and unplug the power.Look on the back of the machine find where the monitor is connected.There are two places to connect a monitor.The first is kinda high on the machine and is blue,if you are already plugged in to the blue one the mother board is bad.Take it to a shop for repair,or buy a new computer.If the monitor is plugged into the white slot you have a bad graphics card and need to replace it.
Jul 13, 2011 | Computers & Internet
Bought barebones(B69-9005)hade trouble installing win 7 kept saying no signed driver,. called them , they sent me soft ware for driver install. started dowloading then stoped. now monitor just reads no...
If it has onboard video it may be a bad video cable or messed up pin on one af the connectors. If it is a installed video card the cable could still be one problem but also try pulling the video card out unplugging the power supply cable from the mother board for about 20 seconds or so. Then reslot the video card into the mother board and plug the power supply back into the mother board and see if that helps. I have also had to take the small flat battery out of mother board for a second or two to make it reset. If you decide to do the battery thing make sure the power supply is unplugged from mother board. Good luck.=)
Sep 19, 2010 | Computers & Internet
No display, no cpu fan running, no any beep but led on mother board is on.I replace power supply but no result
Do the following to check motherboard.
1. Take out all cards from motherboard except video card. Unplug ribbons to CD-Roms, hard drives and floppy drives.
2. The only thing plugged into your motherboard should be video, keyboard and ram.
3. Check once again that all the power connectors from the power supply are properly plugged in. There may be two or three of them depending on the type of motherboard. Try turning on system. If you get no response then try next option.
4. Find the wire coming from your power on button and trace it to the motherboard. Pull the wire off and use a screwdrive to short between the two posts. If the power button is bad this should start the computer. If not your motherboard is probably toast.
Sep 30, 2009 | Intel D845GVSR Motherboard
Signal to monitor goes in and out, mostly out
Hopefully, it is just the on board video that has gone bad, and not the motherboard. When you install a video card on a PC, that has on board or integrated video, you will need to access the BIOS screen on start up and disable the on board video. That way the video signal will come from the new video card and not the on board video.
I hope this helps,
Eric
Jan 18, 2009 | Gateway GT5220 PC Desktop
Compaq Deskpro - video problem?
i got ur answer that is once remove the ram and clean it and keep again. Maximum it works other wise check the load is comg frm smps or not 5v to mother board r not
Jan 12, 2009 | Dell Optiplex GX280 (99301) Motherboard
No start up , button lites up - cd-rom wont open , noticed no fans on for 3d card or big one on mother board
If the cpu/heatsink fan isn't turning then most pc's will shut down to avoid further damage to cpu & board. I would first replace the fan if it's the one over your cpu. Try replacing power supply. If your board has the 4 pin plug, you must have that plugged in. But keep in mind if that fan isn't running a new power supply isn't going to make it start working. You have to have that fan working. Then go from there. If once it is working & other devices like video and/or roms aren't, check your memory. The best way to troubleshoot devices are to plug one at a time in and power up until the problem starts. Hopefully you won't have to go to that step.
Aug 14, 2008 | E-Machines eMachines Desktop PC
Pc starts and runs but wont boot up monitor shows no signal
1) When you turn on the computer, watch and listen for:
a) power supply fan, (power is on)
b) chassis lights (power is on)
c) ticking sound during memory test
(the BIOS POST is running)
d) beeps or rhythmical error codes
(POST failed, bad CPU, CHIP set, memory or video)
e) Monitor either comes on, displays garbled video,
displays a No Sync or No Signal message...
No depending on how far it gets:
Check power supply, cables etc.
Check video cable.
Check monitor with a different PC
Now unplug the power cord, with the computer still
on, this will help drain any internal capacitors.
Wait 5 minutes, then shut off the switches,
and open up the box. try the following,
one at a time:
2) Remove all I/O cards except the video card,
and don't plug them back in until the problem
is fixed. Unplug all the ribbon cables from
the mother board as well:
Hard drives, CD drive, floppies etc.
Make sure you make notes about how to plug it
back in, and cable orientation !!!
0) Re-seat all power cables: Red, Black Yellow harnesses.
1) Unplug and re-seat the video card
2) Similarly, re-seat all memory SIM/DIM modules,
3) Re-seat the CPU
4) Replace the video card
5) Replace memory, CPU or whole mother board,
Plug the good parts back in one at a time,
and test the machine.
Save for the power supply, there really is NO way to test
and isolate a bad module except by swapping/ trial and error
because of inter-dependencies.
For example a bad I/O card, any I/O card, can short circuit
the I/O bus, causing all other plug-in cards to stop working,
or even the main mother-board to freeze during the POST.
A bad power supply ditto.
A bad memory chip ... ditto.
The type of electronic instruments required to actually
test modern computers running at Gigahertz speed cost
hundreds of thousands of dollars, some cost millions, and
are only available to hi end manufacturers
Even the power supply will not power up for a voltage check
if the mother board is bad, although you can use a jumper
on the green wire to ground to force it on, when you unplug
the power connector from the mother-board, if you are brave.
Computer shops carry a lot of spare parts, and their service
department has gutted computers rigged up as test jigs.
They trouble shoot your system by either plugging your
stuff into their jigs, one at a time, or by plugging known
good components into your computer until the problem
is fixed.
This if of course possibly dangerous, since one bad part
can also fry other good parts that plug into it, or that it
plugs into. The compute shops, of course charge you
enough to make up for this.
If a computer is partially operable, it is also possible to
run software diagnostics.
If not, swap and pray is the only way.
Hope this helps
Please rate my answers, martin.
Jun 25, 2008 | HP Computers & Internet
Power up
pull everthing off board but power supply ram cpu and heatsink. then try to power unit.
May 08, 2008 | E-Machines eMachines Desktop PC
Power problems with Dell Dimension 4600
Your mohterboard seems to be bad! If you have replaced the power supply and placed all connections in the rightful place, with no result! Your Motherboard is definetly bad!
Nov 29, 2007 | Dell Dimension 4600 PC Desktop
Intel Core Duo T2600, 2.16 GHz Core Duo (BX80539T2600) Boxed Processor Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
