Question about Samsung CLP-510 Laser Printer
Wrong clp 510 toner
How can I use samsung clp 500 toner in my clp-510 printer ? I kust can't get my toner refund.
Samsung clp 500 toner cartridge can not use samsung clp 510
bcase clp 500 is without chip and clp 510 chip base cartridge so never u can user.
Posted on Jan 01, 2009
Use the electronics from the "correct" toner.
Just change them. Thats the only differens
Posted on Dec 27, 2008
Samsung CLP 510 just replaced transfer belts, imaging unit and fuser but now am getting what looks like wet spots on the prints
Some toner may have spilled in the printer. If so, you will need to clean it out. Also, the toner cartridge may be defective and letting too much toner out at one time, the solution is to replace the toner cartridge.
Take care.
Jul 20, 2010 | Samsung CLP-510 Laser Printer
The printer refused to print, while giving me a "replace black toner" message. The toner did not feel empty, but I replaced it anyway. There is a brand new toner in the printer, but I am still getting an...
it is a typical new problem for samsung printers. you have to reset the printer. it is a pretty tricky thing to reset this type of printers because you can "blow" it up. try find a local workshop, or a specialized person to do this
Jan 25, 2010 | Samsung CLP-510 Laser Printer
Instead of changing black toner printer (samsung clp-510)is giving error INVALID TONER BLACK
This can happen if you install a CLP-500 cartridge OR a Xerox Phaser 6100 cartridge.
Physically they are the same, but the 'chip' is different.
In the case of the Xerox, it is the programing of the chip that 'tells' the printer its a Xerox cartridge, and the printer won't accept this as valid.
If it's a CLP-500, the three contacts on the side of the cartridge have a resistor (for the capacity of the cartridge) and a falmeproof fusible resistor which resets tha page counter (for that cartridge) when a new cartridge is installed.
Oct 15, 2009 | Samsung CLP-510 Laser Printer
Samsung clp-510 blotchy print-out
Some types of paper can contaminate the image drum, suggest you clean it.
Dec 01, 2008 | Samsung CLP-510 Laser Printer
Getting error message on samsung clp 510 printer
yes refilling will solve the problem.but you have to change the green colour small chip on the side of the toner to make it work,as the new chip will be detected as new toner in the printer.
Jul 28, 2008 | Samsung CLP-510 Laser Printer
Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Dec 20, 2007 | Samsung CLP-510 Laser Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-510 not printing?
Most probably you are using an USB cable that is either too thin (cheap cable) or too long (beyond 6ft.).
Oct 22, 2007 | Samsung CLP-510 Laser Printer
Printer not recognising cartridges.
CLP-500 and CLP-510 toner cartridges are identical in shape, but the internal microchip and toner sensors are diferent. therefore they are usually mixed up, producing the problem just described. If you check your toners and happen to have the correct ones, then have them replaced by your supplier; or better yet, try another company. Not all remanufacturing companies are able to fully reproduce the algorythms contained in such chips.
Oct 18, 2007 | Samsung CLP-500 Laser Printer
Printer not recognizing toner
Too much people confuse CLP-500 cartridges with CLP-510. Although they look the same and even fit inside the printer, the internal chip is not the same.
Oct 25, 2006 | Samsung CLP-500 Laser Printer
Samsung CLP-510 Laser Printer Logo
283 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
