Question about HP Compaq FS7600 17" CRT Monitor
What is the crt monitor hcm782m h.o.t number
Hcl
17" model no hcm782m
what is the ,h.o.t number
  • thirugarasu Apr 14, 2009
    17' hcm 782 moniter increase the bright display showing snowie
  • irfan karim May 22, 2009
    I ATTECH THE MY MONITAR TO PC SADENLY OUT OF RANG MASSEGE IN MONITER SCRIN
Moniter out of range masseg
Posted on May 22, 2009
Monitor problem
Welcome to Fixya Customer support
This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Good Luck
Aug 10, 2009 | Computers & Internet
Monitor ,crt, 17inc, in dead condition.(hcl)
He means it's not worth repairing it's cheaper to get a new one its value is zero $
Aug 04, 2009 | ViewSonic G70fB (Black) 17 inch CRT...
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Jan 23, 2009 | Computers & Internet
CRT MONITOR display
It sounds like this monitor may have what's called the "Windex syndrome" in TV repairs. If someone cleans the screen with a spray cleaner and it drips down the face, it can get onto the circuit board and cause intermittent button troubles. Sometimes it's possible to clean off the corrosion from that area, but the most reliable fix is to clean the board, replace the switches, and remove, check and if necessary replace any resistors connecting to the switches.
Nov 18, 2008 | HP Compaq FS7600 17" CRT Monitor
Monitor display
Appreciate the direct "Ask Me"
Unfortunately, an HCL HCM782M monitor is an unknown model. However, on similar instances and occurrence of this problem, it would seem that the controls are damp. Specifically, it would be the internal contacts of the buttons. Pls check if you can dis-assemble, remove the board/control/buttons and perform cleaning. Pls pay particular attention to the rubber pads or the small buttons themselves. if I may ask, any recent continuous rain? If yes, this may have contributed or caused your problem.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Computers & Internet
Display on menu
Hi again,
It would seem that you posted your problem several times. As stated in my proposed solution in your other postings:
Display
Hi again,
Nov 14, 2008 | E-Machines eView 17f3 17" Flat CRT Monitor
HP Compaq FS7600 17" CRT Monitor Logo
342 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
