Question about Dell Dimension 4550 PC Desktop
Clarification of power saving option problem
The monitor doesn't shut down is how I know it isn't working.
  • busterf Dec 30, 2008
    I know it isn't working because the monitor never shuts down.
  • rebelyes1 May 11, 2010
    What is it set on in the bios?
  • 51 Answers
Go to control panel
go to power options
change how long until the monitor shuts off on ac power
Posted on Feb 17, 2009
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
My hp v75 monitor doesn't come on. All the lights
Make sure the VGA cable is properly inserted to your pc and monitor
Jun 29, 2012 | Computers & Internet
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
Gateway monitor 2100 won't turn screen on, blue lite is on as if monitor is. but screen is not on. can it be fuse or what ? is not v-card
It sounds like the lamp for your monitor is no longer receiving power. While you can attempt to fix this issue yourself I wouldn't recommend doing so as it doesn't mean it will work after you attempt it.
If the monitor is under warranty still then you should contact the manufacturer about a RMA. If the monitor isn't under warranty then you should purchase a new monitor.
Nov 26, 2011 | Gateway Computers & Internet
I have a Samsung syncmaster 2233ws monitor every time I turn my monitor on it stays on for about 2 to 3 seconds and then it goes black I checked all of the capasitors on the mother board and they all...
I would still lean toward the computer being the issue. A lot of newer monitors will pop up something like "no signal" for 2-3 seconds and then enter power saving mode by default. If your getting at least this for a few seconds I would say the computer isn't working. Please note a computer can still have fans and lights going and still be bad. If you have lights and/or fans going I would start by replacing the power supply on the computer.
The easiest thing to do to narrow a problem down is rule out as much as you can. For the monitor if you have another computer, laptop or a friends laptop hook up the monitor to it and test. Monitor works then you have narrowed your issue to your computer. If the monitor still isn't working (you need to toggle the display generally on laptops [fn + F7] usually) then you know its the monitor.
By the way Samsung generally has a 5 year warranty on monitors.
If you have ruled out the monitor and power supply I would then try the following
  • If you have a dedicated graphics card, remove it and plug monitor into on-board video. If it works you know its the graphics card if it doesn't then it's most likely your motherboard.
  • Also can try completely unplugging the computer (pull power cord for 30 seconds) computers don't really turn all they way off usually they sit in S5 power mode)
  • Can also try pulling (if you have more than 1 stick of ram) pull all but one out and try powering on, repeat for each stick until it works. I have seen bad memory prevent computers from booting
Comment back if you need further assistance
Aug 23, 2011 | Computers & Internet
My HP w2007 has started clicking to Monitor Going to Sleep and then going blank. I have never known how to wake it up so I have to turn the whole computer off and restart. HELP
Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP. And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
Jul 28, 2011 | HP Pavilion F1523 15" LCD Monitor
After an hour or so of no use, my flatscreen monitor goes black. If I disconnect the computer for a few hours it will come right back when reconnected. Only happens to a flatscreen. A CRT will work fine....
Perhaps the power saving feature?
If you are sure this is not the "power save" feature, then the display have an overheating part. Overheating semiconductors and broken inverter parts are a common issue on Flat screens. You can do a simple test to determine if this problem is caused by a overheating part:
Turn on a fan directly to the display and let it working. If the display doesn't go back when is cooled down by the fan, that means it is overheating and will break soon.
Oct 10, 2009 | Dell Computers & Internet
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
Analog power save
same as above asking for a friend who does't know about commputers
my email is mssposs@bigpond.com
Nov 19, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Dell Dimension 4550 PC Desktop Logo
23 people viewed this question
Clive
Clive
Alun Cox
