Question about Compaq Presario 5000 PC Desktop
I'm tring to install a dvd writer and can't get the door off!
I'm scared I may break it , I have the side off and I lost my computer manual , which doesn't help .It won't fit unless I take the door off and I tried to fit it through the back and there isn't enough room .Thank you so much for your time .
  • helplessblon Dec 29, 2008
    Thank you ,the web site helped me take the whole front off and put un the dvd writer and hook it up . Thank you very much for your time .
  • 51 Answers
Seems like the Presario 5000 only has two drive bays, so your best bet is to remove one of the drives that you don't need anymore and replace it with the new one. You will have to open the side, then you should see some screws holding the drive in place. Unscrew those (might have to fit your screwdriver in some tiny holes to unscrew the screws on the opposite side) then slide the old drive out the front of the machine. Slide the new one in place, plug in, and you should be good.
Here is a link with all the infor you need. Hope this helps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03429&lc=en&cc=us&dlc=en&product=92867%E2%8C%A9=en#N578
Posted on Dec 27, 2008
Installing a DVD Writer in open slot/replace the current drive
this plate is a cabinet safety plate just as a slot of our PCIE ...just twist that plate from one side so it will brake at two end tips and then install your dvd rw...
Aug 19, 2009 | Dell Inspiron 530 Desktop Computer...
Working only with CD, but can not start any DVD
open your device manager , off a right click from ,,, my computer . click properties , hardware tab , then un-install both the cd and dvd . re-start your system and let windows detect the new hardware and re-install it for you . Let me know if this works .... if not we can troubleshoot further.
good luck
May 24, 2009 | BenQ CB523C CD-RW/DVD-ROM Combo Drive
SAMSUNG DVD Writer . Have lost Key Number What to do
You may ask your retailer. If there is nothing specific in NERO then you can use any free tool.There are many free CD/DVD writing softwares on the net.Search in downloads.com and google.
Don't loose heart this is not a big problem.Register your DVD writer on SAMSUNG website and then drop a mail to support on the same website for the key, they may respond.
Mar 15, 2009 | Computers & Internet
I've been trying to install a dvd writer and figured out everything (I think) except how to get the door off ,I feel I may break it if I force it .
This DVD writer needt be serviced at the local computer shop. As the Drive gear which are used to open & closed the door are not aligned properly are they may have got broken.
Dec 27, 2008 | Compaq Presario 5000 PC Desktop
Upgrade medion pc 8366-8233 128 &256 megabytes installed mem 1.67 gigahertz amd athlon xp windows xp service 3.I would like to add a usb 2 card. and a dvd writer
Right, this is simple, just like puting blocks in a baby toy. Just messing, if you don't know what you're doing it is hard.
Consult your dvd writer's manual for instructions on how to install the new device, it should have come with a Cd as well.
The usb 2 card, i'm assuming, is some type of bus card. AGP, PCI, PCI - E. So, here's the baby toy part. Open the computer case, after it's turned off and be sure to wear a grounding bracelet or constantly touch the metal side of the case, DO NOT touch the motherboard with a magnitized screwdriver, or your fingers unless they've been discharged on the side of the case (static is deadly to computers) (note this process may void your warrenty, as will the DVD writer)
But it sounds like it's an older computer, so i'm guessing pci slot. Locate an empty PCI slot, or whatever they all look the same, You can google the PCI slot to see what it looks like. After you locate it unscrew the screw on side that opens up to the back of the computer, unscrew it and remove the plate. I'm sure all this is in the usb card's manual as well. Then just stick the card in there ther right way, and screw it in place, wel-ah! Then you will need to get your driver cd or download the drivers from the manufactorer's website.
Have a good day,
Some dude
Dec 23, 2008 | Medion Computers & Internet
Iv lost softwear
Try to download any free DVD burning software like nero. from
http://download.oldversion.com/nero6614.exe
Nov 23, 2008 | HP DVD1040i 20x Super Multiformat Dvd...
Installing
Hi tatieyanah...
For installing your DVD Writer follow these steps...
First , Place your DVD Writer in a Suitable position and fix it by the screws.
1. From your CPU SMPS(i.e, power box) you will have many set of wires coming with white plugs.Take one of those wires. Plug that into your writer's back side.REMEMBER you should plug it in the way that Yellow color wire should in the outer end and two black wires in the middle and red at the inner end.
2. If you dont find any wire in your CPU , use the one which is given to you ,which is a splitter in the DVD box.
3. Use the data cable given along with the DVD writer. Connect that Data cable( cable which is Wide and looks like stripes) from ur Mother board to the back side of the DVD writer. Take care that it is not connected upside down.
IF U NEED MORE INFO, REFER "http://www.computer-adviser.com/how-to-install-dvd-writer.html".
Post me your replies.....Bye ...take care...
Sep 17, 2008 | Computers & Internet
Install LITEON 18X Super AllWhiteDVD/CD Writer&Rewriter Serial no 1502-4020-1203-0757-1127-2659
Lost your DVD Writer means ?
Does it stopped working !
Open The cabinet of the CPU and check the IDE Channel
BUS- cable if that is plugged properly.Also check if the Power plug is properly inserted to your DVD Rom,
If both are checked properly, get the lense of the DVD checked in service center. maximum of the CD/DVD problem arises due to damage in the lense. Anyways, The cost of the lense comes to be almost equal to the DVD ROM price  :)
Pease rate if this fixes your problem
May 27, 2008 | Computers & Internet
LG GSA-H62N WILL NOT INSTALL ON MY COMPUTER WITH VISTA HOME EDITION
Please check and let me know the exact model of your computer. If you have a door in front or on top you should see the exact model number. I want to make sure your system can handel a DVD writer. Are you replacing a cd with a DVD writer or adding a 2nd drive? On all compaqs the the new DVD drive needs to be set to CL(Cable Select ) on the back of the new DVD drive. Also make sure you have the right IDE cable and power.
Jan 05, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
37 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
