Question about Nintendo DS Lite - Onyx
DS Lite Issues
Okay first of all i opened the 5.2v=In thingy and i was working on my phone as well and well i didn't realize that it then became in contact with my phone. Now the Darn thing won't even charge on the Usb charger and won't even turn on Gah Please help me i'm so dead my parents can't afford another DS or a battery.
  • 4 Answers
SOURCE: Nintendo DS Lite - Not charging
sounds like you've blown a fuse inside the ds itself. Check on the underside of your console and check if it says "5.2v in" adjacent to your charger port if it does then the uk charger is safe to use. But the fact remains you may of blown a fuse. There are two fuses in the ds and are very small they can be repaired easily if you have any soldering skills.
Posted on Sep 09, 2007
msgetlost
SOURCE: ds lite charging lite comes on but when i press power button nothing happens
i left to go to the mall one day and there were a whole bunch of little kids here and i put mi ds on the back of my sofa and wen i came back my ds didnt come on so i charged it for 3 days strait and on the charge button will come on but when it does it stays on for like 2 minutes then cuts of and mii game doesnt come on and the kid didnt do anything but play with it
Posted on May 24, 2009
  • 133 Answers
SOURCE: my ds wont charge or turn on
Have you tried a different battery before anything else? Most of the problems I get with these are the battery
Posted on May 28, 2009
  • 10 Answers
SOURCE: Charge a DS lite without DS charger
turn your ds lite on, then realy quickly close the lid
Posted on Oct 04, 2009
  • 110 Answers
SOURCE: nintendo not turning on after charging battery
If the unit does not turn on at all (no green light) then the chances are you have blown the F2 fuse...
This fuse is internal and is less than 2mm wide on its longest length.
If you have a warranty I would suggest you send it off for repair, if not you can either find a good repair service on the net (such as ebay) or repair it yourself.
If you do decide to go down the D.I.Y route you will need a few specialist tools and some good soldering skills. As I said before the fuse is very small and so you will need a steady hand to replace it.
All the tools and parts can be found on ebay... If you would like some info on where the fuse is, what tools you will need and how to go about replacing it then click on my name to get to my profile page... from there you will see a list of guides I have written, all the info you should need will be in them.
If you need any further help or advice please feel free to contact me and I will help you out as best I can.
Regards,
SOD69
Posted on Apr 23, 2010
DS Lite Will Not Power On
There is a possibility that your battery has developed a short circuit or is so bad that it pulls down the charge voltage on the charger. You are therefore left starved of a power and therefore no function.
If possible, disconnect the battery and run the DS on the charger power alone. If the DS starts to work, I suggest replacing the battery.
Sep 05, 2014 | Nintendo DS Lite
Every time i want to play a new game i leave my ds lite on i take out the clipie thingie and it freezes on me help.
Shut off your nintendo DS before changing the game cartridge/card. Your not supposed to take them out while the system is on.
Jun 10, 2010 | Nintendo DS Lite
My ds won't read ds games, but it reads gameboy games
then u need 2 fix the prong thingys in the back the way i did it is i took the stylest across the prongs 2 straighten them uo
Dec 29, 2009 | Nintendo DS Lite Console
DS Lite: Green light turns on,
Im pretty sure when it gets to the point where it doesn't recognize its own screen is when its time to get a new ds. But if you really want to find out if it can be fixed (and don't mind paying more then its worth) you could to it to electronic shop or best buy to have them look at it.
Nov 30, 2009 | Nintendo DS Lite Console
My DS lite keeps Freezing
Okay if your constantly getting freezeups even after my ideas then that means the mainboard is bad, so unless your ds is under warranty and you can get the board replaced, the ds is bad.
Jul 08, 2009 | Nintendo DS Lite Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Ds loading problem
u throw ur ds on the ground. not plain ground. like a bed or a thck caarpet. this makes the inside particles get into place and not damage anything. if u dont want to risk damage.put it inside a container a littel bit more bigger than the ds. and then put a towel over the ds. now shake the conainer. it always works. only for the ds lite. for onriginal ds, this will break ur screen holder thingy mobob.
Apr 16, 2009 | Nintendo DS Lite Console
Problem with DS lite recognizing stylus.
try using your nail if it doesnt work and try to blow on it.
Jan 10, 2009 | Nintendo DS Lite Console
Green screen
There is a ribbon that connects the top screen of the ds to the motherboard. It is possible that this ribbon became damaged when the hinge broke. A possible fix would be to replace the upper screen. Hope this helps.
Jan 07, 2008 | Nintendo DS Lite Console
DS Lite won't recognize DS cartridge
a wire is probably misplaced.I recommend getting professional help or unscrew your ds and fixing the problem.
Oct 01, 2007 | Nintendo DS Console
Nintendo DS Lite - Onyx Logo
43 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
