Question about Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator
Fridge working fine, But freezer will not go below -8 degrees. there was some ince build up in the freezer which was cleaned, and since then has been working fine, but recently over the last few days the freezer just keeps falllin in temperature when ever door opened. Can you advise? or do i need a service call?
  • Anonymous Dec 13, 2007
    liebherr freezer not working
  • Anonymous Jun 27, 2008
    Do fridge freezer give off a smell when they are not working properly e.g. ice forming on the back inside the fridge.
  • 944 Answers
It does sound like you have a low refrigerant gas problem - only way to be sure is get a service guy to check. If you notice particularly cold parts on the wall of the fridge or freezer, rather than the more even cooling that would be normal, then this is almost certainly the problem, and should be easily enough fixed by a qualified technician. The other possibilities are: The thermostat in the freezer could be faulty -hard to test without the right gear, but just check that the temperature adjustment knob for the freezer if it has a rotary one hasn't slipped on its shaft - this would give you a different temperature than the setting you have set. Check the freezer door seal/hinge and make sure it is sealing properly all around especially at the bottom - only a small gap can make a big difference Check the back of the unit is getting enough ventilation - it should get fairly hot normally but if the ventilation is restricted then the heat has nowhere to go and the freezer wont cool completely - if there is a lot of dust on the back then give it a gentle brush - the pipes are quite fragile so be gentle. If you havent defrosted the unit for a while, try that - leave it open and off at least overnight until there is no difference between the temperature inside and outside - sometimes small amounts of moisture in the refrigerant gas can freeze into crystals and block or partially block the gas system, once they defrost they should be dealt with further round the system by the filter/drier and hopefully will no longer be a problem Hope this helps :)
Posted on Apr 21, 2007
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Fridge freezer
HI jACQUELINE.well i reckon the fridges r a bit temperaMENTAL.:).Before u do anything well u can check weather u have ice build up on the rear panel inside freezer compartment.either way i would first turn it off for 24 to 48 hours.then remove bottom plinth panel (bellow the door).thoroughly clean condenser coils right to the end.then try u could get lucky.if it doesnt work then the problem could b inside the panel.def/heater,fan motor,t/stat,or the board.good luck Ali
Aug 24, 2012 | Refrigerators
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Fridge running at higher than 4 degrees.
I have the same problem with my F&P fridge/freezer although I'm not sure how old it is because I bought it from my landlord when he moved out. I call the repairman who said turn it off and defrost the freezer. I turned it off last night, defrosted the freezer as there was some ice build up internally at the rear and turned it on again. It went fine, I set it at the coldest (gauge on colder) setting and this morning it was quite cold. Today I get home from work and it's hardly cold, no condensation on the lemonade or beer bottles! Will be interested to hear others thoughts before I call the repair man again. thanks, Jenny
Feb 09, 2010 | Fisher and Paykel Active Smart E522B...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Fridge not cold
HI thanks for your question. check to see if the fan motor is running in the freezer. that could be the problem. thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | Frigidaire FRT18B4A Top Freezer...
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Aug 27, 2007 | Refrigerators
Fridge won't cool
most likely its a defective thermostat,if your freezer is still working.Check to see if there is any ice build up.
Apr 12, 2007 | Haier HTQ21JAAWW Top Freezer Refrigerator
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
826 people viewed this question
Top Liebherr Refrigerators Experts
Marvin
Marvin
Paul Carew
Lawrence Oravetz
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
