Question about Frigidaire FRS26R4A Side by Side Refrigerator
Side by side freezer and ref, I have problem with the unit not producing ice, water stream seems so little, i tried to fill in the ice maker compartment with water and after an hour ice was produced but it was not ejected towards the ice container below. I tried to check the motor for and still working but it doesnt seem to work automatically, thanks
SOURCE: The streamer on my x1 has stopped working
Several things I would check here. How old is your machine? Is the coffee coming out hot enough? If not, then perhaps the boiler is not reaching optimum working temperatures and needs replacing. When did you last descale your unit? If you live somewhere where there is a lot of hard water, and you don't prefilter it, then it could be scale build up in the tube. Try soaking only the tube end of the wand in some vinegar for about an hour, then try flushing it with steam once again. Finally, one has to be dilligent in CLEANING the steam spout right after you use it, EACH AND EVERY TIME! (that is why you almost always see barristas with a damp cloth over their shoulder, ready to use). Milk left on the wand will bake on and become quite hard to remove. This will happen on the outside as well as inside the tube. Soak the end of the tube with boiling hot water for about 10 minutes, wipe the end clean, and with a fine wire or pin clean the inside of the steam wand tube. You may have to repeat this procedure several times to fully clean the wand. If you are at all mechcanical, you could take your machine apart, remove the wand, and soak/clean it separately. But only do this if you are a quite confident handy person. Hope this helps and good luck!
Posted on Nov 03, 2007
SOURCE: Ice maker isn't making ice...
check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
Posted on May 04, 2008
Krazytech
  • 725 Answers
SOURCE: Ice maker
is the it turned on and the bail arm down?
Posted on Sep 07, 2008
ukvacfan
  • 328 Answers
SOURCE: Why doesn't my Krups espresso maker produce crema
Crema is the goldish brown top that goes onto the top of the coffee once it is dispersed from the espresso tap and flows naturally as part of the coffee when coffee is made. Im not sure what you mean "blasted."
Perhaps you should flush through the machine with cold water a couple of times beforehand and also consider a descaling kit - check your manual or Krups if there is one for this model.
Crema isn't produced by any machine though.
Posted on Jul 25, 2009
  • 185 Answers
SOURCE: Ice maker only produces 30 cubes per day (24 hrs) since new.
You probably need more water pressure going to the frig. check that first.!!
Posted on Mar 22, 2010
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
Freezer filled up with water from ice maker
That is caused by a defective water control valve on the ice maker side of your water control valve. The only way to repair is replace water valve. Please rate this solution, Thank You, Sea Breeze
Nov 24, 2011 | Refrigerators
I just changed the ice maker on my jenn aire ref. JCD2289AES. The old one was leaking everywhere and making a big frozen block of ice . It seemed very simple but, it the cube tray is not filling with water...
there is a solonoid valve at the back of the freezer section (externally) which should release 7 seconds of water into the ice tray to fill it..
the most common cause of leaking ice makers is that the valve freezes up if not much ice has been used.. and you simply need to thaw the freezer out overnight (put the contents in a cool box, or wrap it in lots of bubble wrap/newspaper and cool blankets to keep it frozen)
that aside, there is a wire ice-stopper that goes up and down as the level of the ice rises and falls.. if it is in the raise position, the ioce maker won't do anything.. you can gently press it down, and things should start almost immediately.
Oct 02, 2017 | Jenn-Air JCB2388G Side by Side...
Add Water issue on Edgestar icemaker
This also applies to the Igloo ICE102.
There is a sensor at the water outlet which fills the ice-making trough, which appears to be poorly assembled. The fix is quite easy.
Remove the rear cover by removing six screws located underneath the unit at the back and sides. Keep the ice-maker upright at all times, per user instructions.
Once you have gently pried the back cover off, remove the top cover and hinged lid by removing two screws on each side, located underneath the top rim.
With the top off, you can see the water outlet at the back left side. Above the inlet is the offending sensor, which has a metal prong angled down. This prong must touch the water stream to detect the flow, but is probably too high. You can check this by filling the unit with water and turning it on. Watch the water as it fills the trough. With the tip of a screwdriver, bend the metal tip down so that it touches the water stream. Run the unit for a while to test.
If everything is ok, then reassemble and enjoy!
Thanks to jimbo from Tampa who provided the hint for this fix.
Jul 13, 2010 | EdgeStar Titanium Portable Ice Maker
WP side-side freezer appears to be overflowing the
You just need a new water valve for this unit. Call us with your midel number and we'll be sure to get the right part out to you right away! We look forward to hearing from you soon.
Oct 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not dispensing to fill up ice maker
Hi: Make sure your freezer is at zero degrees F. It will take 24-72hrs for an ice maker to produce when the freezer is at 0 degrees. Only then will the water fill the trays. I hope this helps, Jeff
Jul 07, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Apr 05, 2009 | Whirlpool Freezers
Unit stop producing ice
Boss, please read the following articles in the link. www.hometips.com/repair-fix/freezer-ice-maker.html
don't forget to rate me!!
Dec 27, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker stop making ice for kenmore 106.56352500
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
110 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
