Question about Compaq Presario 5000 PC Desktop
I've been trying to install a dvd writer and figured out everything (I think) except how to get the door off ,I feel I may break it if I force it .
    Problem Solver:
  • 82 Answers
This DVD writer needt be serviced at the local computer shop. As the Drive gear which are used to open & closed the door are not aligned properly are they may have got broken.
Posted on Dec 27, 2008
Lightscribe dvd drive won't work. the eject command does not make it open either. seems to be jammed. if i break it down can it be "unjammed" without ruining it?
Actually it's probaly just got some dust or something in it. What you do to manually open it is take a needle, thumb tack, or safety pin and simply insert it into the tiny hole above the eject button on the dvd drive itself. You'll feel the tip of the button when you push the pin into the hole then it will pop the door and the drive will open properly. This has gone on for cd/dvd drives for years. Usually just the cause of dust or what have you being stuck in the mechanism.
Jul 01, 2013 | Computers & Internet
My refridgerator isn't cooling I changed the starter relay(thought that was problem) but it still isn't running. I check compressor gets warm but not running
Unfortunately it sounds like your compressor is on its way out. In some cases you can get what's called a "hard start kit" or a "3-1" (same thing) to help force it to run, that does sometimes get you more life out of the compressor. MY GUTT FEELING: The reason it is warm is because it is trying to run but can't, do to a broken winding inside the motor or a piston or valve is jammed or bent. The reason forcing it works sometimes is because it actually breaks pieces off when it is forced so hard. The divit or scratch left behind may continue to break down over time resulting in blockage and seezing, or it may just break a small piece loose and run for years. It is a gamble though. Good luck with it
Jan 17, 2013 | Refrigerators
DELL DIMENSION DVD ROM CODE 10
please install dvd driver cd and software
May 07, 2012 | Dell Computers & Internet
My PC detected my LG DVD reader/writer rom but the rom is not reading maybe you can help me troubleshoot this problem thanks
Make sure the software for this DVD drive is installed into the PC and then your drive is connected to be detected and installed, This will also remove off all previous drives that might cause errors.
Sep 25, 2010 | Computers & Internet
My cd/dvd writer wont work anymore
go to your registry by typing regedit in run or search text box.
then look for this path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
then delete upper filter and lower filter on the list
restart system
if failed try running microsoft fix it on this link below
http://support.microsoft.com/kb/929461
Jun 10, 2010 | Acer Aspire 4530-5889 Notebook PC
Its dvd/cd writer problem
make sure you clean the conections inside then try again and dont force it you could break it beyond repair
i think you might need to send it of for repair (or take to a shop)
Sep 21, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
System hangs up frequently
Might be a loose RAM (memory stick). Try removing it and then connect it again properly and see if it solves the Problem.
Jul 12, 2009 | Intel Pentium Dual-core Processor E5200...
Problem in pc
ve u installed new dvd writer?
Feb 12, 2008 | Microsoft Windows Vista Ultimate Edition
Dvd writer problem
If everything works fine except that disk then its the disk its self.
either there is a scratch on the disk or it was a bad burn from the manufacturer.
Nov 03, 2007 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
