Question about Rockford Fosgate Pl1 210 Stage 1 Dual 10" Hatchback Subwoofer
How to buy the best subwoofer
I have pioneer shallow subwoofers now and was wondering if 10'' rockfords would sound better than these. I have limited space but enough to fit 10'' subs.
  • Anonymous Dec 28, 2008
    They are 12" premiers and are 1400 watt peak power
  • ricky horwood
    ricky horwood May 11, 2010
    what size are the pioneer subs and what are the power handling on both
    New Friend:
  • 15 Answers
There are several factors to what sounds good in a subwoofer. Your head unit, amp, enclosure size and enclosure type as well as where its placed. I tend to think that fosgates are superior to a lot of speakers but orion and JL are making some pretty impressive speakers too. Check the speakers need for airspace and make sure you can accomodate it. If you can, and the resonant frequency is more to your liking then move up to fosgates. Personally, I think the difference MIGHT be minimal assuming you are using the same inclosure, amp and head unit. Good Luck!
Posted on Feb 28, 2009
What car amp should I get to power my 2 pioneer ts-sw3002s4 sub's. They are 12 shallow mounts 4 ohms each with 400rms each.
Rockford Fosgate R1200-1D Mono subwoofer amplifier - 800 watts RMS x1 at 2 ohm, 1,200 watts RMS x 1 at 1 ohm
Mar 26, 2015 | Pioneer Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
When I am listening to my stereo in my truck with a pioneer headunit and a rockford fosgate p1 10" subwoofer. I listen to music and part of the song will hit hard then it will weaken dramatically. What is...
Your amplifier is going into protect mode.
It may already be damaged from repeated abuse.
The subwoofer is either bottoming out... has a blown or damaged coil... or your charging system is not adequate to keep your batter charged above 8VDC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 26, 2009 | Rockford Fosgate Car Audio & Video
My subwoofers will make no sound now
Go through the multiple menus of your head unit, and make sure the subwoofer setting is set to "yes".
Do you have the owner's manual for the unit? What make/model is the head unit?
Mar 06, 2009 | Rockford Fosgate (P212D4) Car Subwoofer
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Sub installation
You would be better served to go to a local shop and get the correct fittings to fit the connections, and use those to connect your subs. Just running the wire tips will result in loosed connections and plenty of headaches..
Jan 04, 2008 | Rockford Fosgate Punch Stage P110 S4 Car...
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
One or two
IMO 2 would be best. A good 10" woofer will give you good all round bass but wont rock your block off. The bigger your woofers the more low end base you will be able to produce so a 10" is a good balance between low end and thumpy bass for a full sounding system. The type of box you decide on encosing the woofers in will also affect your sounds. Consult your local car audio experts for more info. Good Luck
Apr 24, 2007 | Pioneer TS-W251R Car Subwoofer
Rockford Fosgate Pl1 210 Stage 1 Dual 10" Hatchback Subwoofer Logo
155 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
