Question about Tissot T-Touch T33759851
Can't figure out how to set DUAL times on the Tissot T Touch-
What I really want is the LOCAL time on the watch hour and minute hands, and GMT time on the digital........is it possible ?   I assume it is since what I have read is that dual time setting is possible, but I don't want the analog and digital to mimic each other (ie not military time on the digital)
Example: 8:00 AM on the analog hands would correspond to 16:00 on the digital.
HELP........THANKX !
  • manitou2 Jan 16, 2009
    I cannot synchronize digital with analogue hands. Instructions in manual not clear.
    Please explain.
    Thanx P.R.
  • aarthi20 Feb 22, 2009
    I want to set a dual time on my T-33759851.
5 Suggested Answers
SOURCE: tissot t touch, time problem
you need to calibrate it.
go to the '24h Cm' screen [T button, then touch centre screen few times]
hold down T button for 5secs
use + button to bring minute hand to 12 o clock position
use - button to bring hour hand to the same place
press centre of screen and it's done!
Phil
Posted on Aug 06, 2008
  • 2501 Answers
SOURCE: Synchronize analog and digital time on Tissot T33 T-Touch Watch
I could not get any result from entering your model in their web site but the "T Touch online" seems to be a watch that has similar features perhaps.
Their catalogues seem to be generic, so by going to their web site http://support.tissot.ch/?mod_flashPDF/id_138 you may finswhat you need.
Posted on Apr 17, 2010
mark_vici
  • 58 Answers
SOURCE: Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
Posted on May 03, 2010
SOURCE: setting my Tissot touch Navigator 3000
Per the manual: http://support.tissot.ch/usersmanual/140-en.pdf
When your battery begins to die, the hands are no longer synced.
After replacing the battery, go into local time mode (pressing the center of the crystal) until "Set" appears. Press the crown. Scroll to "ECO BAT", press and hold the crown for 5 seconds until "SYNCHRO" appears. Use the "+" button to move the minute hand and the "-" to move the hour hand until they are in the upright or 12:00 position.
Either press the crown again or wait until the watch automatically leaves the Set mode. Your hands should now represent the local time.
Posted on May 25, 2011
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
How do i set the the 24 hour hand in a rolex 16758
Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
Apr 30, 2010 | Bulova Watch
How to set and use the subdial on my invicta model 5749 gmt watch
While I'm not familiar with that particular model, most GMT hands are set by turning the crown "backwards" in the date setting position. IOW, if you set the date by pulling the crown out to the first detent and turning it clockwise, turning it counter-clockwise will set the GMT indicator.
Apr 10, 2010 | Bulova Watch
T-Touch Analog time is 1 hour off digital time.
Go to "www.tissot.ch/" and at the bottom of page, click on "warranties".
Click on "user manuals" and enter details of your watch.
Feb 24, 2010 | Watches
Setting my Tissot touch Navigator 3000
Feb 08, 2010 | Tissot T Touch Navigator 3000 T96.1.478.32...
Sep 22, 2009 | Tissot T-Touch T33159851 Wrist Watch
Tissot t-touch analog time is out of sync with digital time. How do I res-sync them?
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
Jun 04, 2009 | Tissot T-Touch T33759851
Tissot t touch, time problem
Phil
Jun 29, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Jan 12, 2008 | Tissot T-Touch T33159851 Wrist Watch
Synchronizing the manual and digital clocks
Push the middle button then touch the centre screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds."Synchro" will appear on the display. By using pushers + and -, bring the two hands pre-cisely to 12 o'clock Incrementation of the minute hand(3 steps=1 minute) Incrementattion of the hour hand(3 steps=1 minute) Press the middle button to validate the setting.
Jul 06, 2007 | Tissot T-Touch T33759851
Tissot T-Touch T33759851 Logo
188 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
