Question about NEC PlasmaSync 42PD3 42" Monitor
Thin red line in middle of screen on nec 42vp2a 42" plasma monito
Thin red verticle line in screen on nec 42" plasma monitor model 42vp2a
  • dekdrb Feb 06, 2009
    thank you for the advise. Your answer was correct. If you could be more specific next time on where to look for these issues would be cool. At anyrate, thank you much. IC was faulty
  • gazduz Apr 14, 2009
    I've got a thin red line from top to bottom on my 42" Plasma NEC42VP4G/S(Australia) too. You mentioned that it was a problem with the IC - how was this problem rectified?? Do I need to take it to be serviced, or can I fix it myself??
Dry solder in vertical section or ic faulty replace it
Posted on Dec 27, 2008
Thin red line on middle of screen near middle(verticle)
It should have a technician for a lot of reasons-- verification of symptom, experience, part # look-up, warranty. You can usually get a diagnosis of parts and labor for a leesor charge.
Apr 19, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I have a thin green verticle line on my LG flat screen tv.can i fix this inexpensivly?
I'm afraid not, this will be a defect within the screen & the only remedy is to have the screen replaced.
Sep 23, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Red line in the middle of my plasma screen
Hi leprecoce,
One transistor out of millions has failed shorted. That is an unusual failure mode, but not unheard of. The chip can probably be replaced, you might want to check google maps or for a repair shop near you.
Most shops should be able to give you an estimate, I would guess around $300, unless the chip is hard to get.
Nov 01, 2017 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Nec 42
who has manual for a nec 42 plasma monitor px-42vm2a date it was made is 12-07-01 it is a flat screen thank you email
Apr 04, 2008 | NEC PlasmaSync PX-42VP2A 42 in. Television
NEC PlasmaSync 42PD3 42" Monitor Logo
419 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
