Question about Frigidaire FRS26R4A Side by Side Refrigerator
Unit stop producing ice
No ice production, pump BW2000 model still working but it seems not strong enough to pump water, although when water dispencer still working but on a very slow discharged rate. tried to fill in water on the freezer container after an hour the water gor freezed, the ice produced were not ejected and drop to the collector dispencer below ice maker still working but there are problems with filling water to it.
  • 294 Answers
Boss, please read the following articles in the link. www.hometips.com/repair-fix/freezer-ice-maker.html
don't forget to rate me!!
Posted on Aug 28, 2009
Ksrs251 ice maker will not stop making ice and it is overflowing. Sensor seems to be out and off switch not working.
Although your model number supplied is incomplete, you have an optic sensor in your unit, so either your sensor has failed or has be rewired. Your optics are located on the side wall of the freezer section and use a laser to detect ice volume. Does it produce when you turn this off? If so, replace the optics Part Number 4389102, this part does come with both boards for both sides. Check it first by turning it off and see if production has stopped, if it is shorted it will cause continuous production of ice.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 29, 2013 | KitchenAid KSCS25FKSS Side by Side...
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
The ice dispencer would produce ice
Dear Adriana, I have the exact problem. I have yet to find a clear solution to this problem. The temp in the freeze seems to oscillate too much, and the leaking water led to a damaged light in mine.
Have you discovered a solution? It was recommended by a repairman to replace the controller board for the unit. I have yet to implement this approach. Wondering what others have discovered.
Marco
Dec 06, 2009 | GE PSC25MSS Stainless Steel Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker not working
Cause could be the solenoid valve which controls water flow into the ice maker.
Could be bad solenoid, bad relay for solenoid, clogged solenoid valve, corroded electrical connections, etc.
More info? Let me know...
Charlie
Aug 14, 2009 | Refrigerators
We have a Whirlpool K40 Ice Maker but it seems to have stopped producing ice. The motor is running but there is no water coming into the machine & therefore no ice is being frozen & cut by the...
a few things to check, first off is adequate water supply(obviously).. next check your drain system, if your unit gravity drains look for a blockage, but if you have a secondary drain pump to pump away water check for proper operation, if that pump fails the machine will no longer let water in( thinks it full and no need to produce more ice if it cant get rid of old water
Jun 09, 2009 | Whirlpool Freezers
Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 09, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
Water dispenser does not work
The lines are likely clogged and will need to be removed and cleaned. Otherwise, although the pump starts, the valve may be clogged or non-functional.
Feb 11, 2018 | KitchenAid KSSS36QK Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
174 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
